I would also imagine the crossover set-up may be more prone to overheating during long runs at higher rpms
We'll you'd know best, I thought heat transfer would be less effective if the water travels through the motor too quickly.I think just the opposite.
Thermostat on the oil cooler will get the temps up quick!!!!
Most oil coolers are to big for the engine and are over kill
Running a thermostat on the cooler can keep the milk shake and whip cream out the engine and make the engine run warmer with the crossover system
Are U pre warming the water in the exh before it heads to the engine block
My set ups the cross over deal with an oil cooler. I have made many long runs and the temp always stays static. Engine built by Carson Brummett.I think just the opposite.
never a bad idea especially if you boat in lakes that have alot of bloom, weeds etc.Do I need to run sea strainer
