Cavitation Plate Question
1fastsedan
You can always mount an electric actuator like this and throw the button on the steering wheel. Makes for and easy drive. :)
lenmann
SoCalZero
Donโ€™t let those electric guys reel you in. Haha. Nothing better than a nicely built dual petal setup. If you are really gonna drive the boat I feel that manual plates are the way to go. From the looks of your progress so far whatever you choose, it will be awesome. Looking forward to the rest of the build.
cj222
Cool pad design and nice machining. What mill are you using? I'm curious what your process was in machining those notches and angles. Plus, you did 12! Care to enlighten me?
Thank you! I am using an old Lagun knee mill. It use to be a functional 3 axis cnc but no longer works so I have been using it as a manual machine with a digital read out to know my positioning. The real shitty part about it is that I do not have a functional quill like you would on a drill press so I have to raise and lower the table to do any drilling and countersinking. As for machining these blocks, it was all about my setups and order of operations to make these the old school way. I made a fixture block also for my setups.
GETBOATS
I'm an outboard guy and even I like it!!! Machine work and creativity is great.
cj222
Thanks bud . I am undecided on what I am going to do lol
poncho
How hard would it be to set it up manual to get on the water and add the electric actuator later and retain both systems in case the electronics fail?
Never set up a cruiser before but I like back up systems
cj222
Not really sure lol
mattyc
Sorry for the twenty questions. I see you have an angle at the front of the notch, an angle on the top and the notch angle doesnt appear to be perpendicular to the top angle. It looks like you would have had three different holdings? I'm trying to imagine the order of operations. Definitely some time involved ๐Ÿ‘
cj222
Haha yeah, I had 12 different setups to make these parts on the manual mill
coolchange
Lower level functionary
You want electric plates just replace the over ride handle with a linear actuator.
Arc path of those plates is pretty severeโ€ฆ
vstdispatch
I agree 100% it's way more fun with a down pedal and when u don't want to use it lock it out with the handle way more fun to drive and u feel everything the boat is doing and are in more control then waiting on a electric motor. I get bored driving boats with nothing to do while driving but what do I know
1fastsedan
The comments on electric vs manual. If you "drive the boat" go manual. We've been running electric plates for over 30 years with zero issues (race and pleasure). We run the piss out of our Schiada and I love having electric plates. It works instant without thinking, just hold on and drive. User preference of course.
ArcadiaBrad
Question from a non-v drive guy. Is there a hinge point at the transom, or are you only using the flex of the metal?
1fastsedan
I think this is it
papabear639
I think this is it
This is really cool, I actually didn't realize there were so many variations of the "down pedal". I have a down pedal and lockout handle on mine and I dig the feel of constantly adjusting for the water conditions. I have to admit a button would be pretty cool though, does the actuator react quick or is it more like a trim button in an I/O?
1fastsedan
The button is instant. I can work our Schiada over any water with a push of a button. My dad had a prop walk around his hand/arm in Parker in 88/89. So when he rigged his Schiada in 90 he had one of the first electric cav plates set ups. His left hand "gimpy" we call it, has a hard time with grip and going electric made it easier for him to race.
cj222
๐Ÿคช I do, just not a lot of sleep lol. Thank you for the compliment bud ๐Ÿ‘
coolchange
It flexes the hull. There's a great write up by RiverDave on this topic.
Think about this for a second. Bends the stringers? Bends a v bottom? Flexโ€™s thru the chine and transom?
1fastsedan
You got it. Did you read the article by Riverdave? Its a great write up. I guess I should have been more clear as it "bends the running surface" sorry for the confusion.
"They are basically an extremely efficient trim tab, that has the ability to add positive trim as well when they are in the up position. Picture a trim tab as dragging a plate in the water to create lift, where as a cavitation plate you can move it very little and create a ton of lift, via bending the running surface, instead of dragging something behind the boat."
coolchange
Donโ€™t need to read an article how a cav plate works. Not tryin to be a d just sayin. Didnโ€™t want someone who doesnโ€™t understand to be mislead โ€œ flexโ€™s the hullโ€ ๐Ÿ˜€
TonyFanelli
Good to know! My 67 Lavey has just the lockout, but the Kalawain I picked up has the left pedal/lockout. The maiden voyage if the Kalawain yesterday kinda spooked me a little as I started accelerating, the nose went way up and indeed felt like I was being dragged down from behind. Any suggestions for a new to the left pedal guy?
I guess it might be trial and error next time I put it in the water...
TonyFanelli
Has anyone seen/had fins on their cav plates??
I haven't and have no clue what they're there for...stabilization?
