BLOWN HOWARD
- Sep 24, 2007
- 1,295
- 315
Having a hard time with trailer tires. How many people running car tires on the boat trailer?
is it the right rear?Just blew out another car tire yesterday on the way to Havasu. I need to find another option as this has to be the 5th tire blown going there from bullhead over the last few years
it doesn't matter what tires, what matters is the load rating, trailer tires have a higher load rating and use more air pressure... so say you use a tire with a load rating of 1500 lbs,...running max air pressure, you are only at 6000 lb gross... most tandum trailers are at 7000 lb, so now you are at 1000 underrated tires....most trailer tires blow out the right rear...reason for this is the trailer is wider than the truck... going down the road you will run the trailer tires on the right off the driven path.... so the right front will throw nails and such right into the the right rear...boom... blow out...the next thing you "MUST" do... run the max air pressure...car tires will work good on trailers if they are load rated....I see people with 80 psi tires running at 50 psi... you cut the load rating in half ... so say it was 2500 lb rated ... now it's at 1250lbs..running low pressure causes heat... heat causes blow outs... if you have more than one blow out you have to stand back and look at what going on..watch the mirrors and see where the tires are traveling down the road... stop at 50 miles and see if the tires are getting hot... if they are, and you are at max airpressure... time to go to bigger tires..or higher load rating... tires are designed to roll down the road at rated load...Having a hard time with trailer tires. How many people running car tires on the boat trailer?
not try'n to rub you the wrong way...but UR doing some thing wrong...Just blew out another car tire yesterday on the way to Havasu. I need to find another option as this has to be the 5th tire blown going there from bullhead over the last few years
What would a 26ft cat and triple axle trailer weigh? Ballpark 6k-7k
what brand is the tire,??? and what's the date code???
It varies. Never really the same tire. Last year the spare exploded while hanging on the trailer. At first i thought it was the dips on the 40 east cutting the edges but the tires are just blowing apart. This is the tire size.
What size are you running? I can't find anything.Run 14 ply steel trailer tires and don’t look back.
The cheap ones are as good as the expensive ones.
Cooper tire stores has them.
They look serious too.
My trailer has P235/60R14. It's a 97 Extreme and it has very low mounted fenders. I can only find one trailer tire in that size and no LT tires at all. It still has the cooper cobra tires that were on it when I bought it. They have worked pretty well so I guess I'll just do another set which will probably be the beginning of next season.
I currently have about 38 lbs of air in them and I guess I should bump it to the max rating.
It’s all about managing heat! Keep the heat down they will do just fine.
Ways to keep the heat down
Keep Air pressure up
Don’t overload
Bearings spin and brakes don’t drag
Don’t go 80mph
You’re likely overloaded and don’t really have many options at that size.
An ST trailer tire is gonna be your only option. And if you’re at 8k lbs you’re still pushing it.
Here’s why trailer tires suck:
For any tire, load capacity decreases as speed increases.
Like all tires, trailer tires are load-rated at the tire’s speed rating.
And ST (trailer) tires carry a 65 mph rating.
There’s no headroom.
The shittiest car tire is going to have a speed rating of S (112 mph) or higher. Which means it can carry it’s rated load at this speed. And gives you considerable headroom at lower speeds.
You need to weigh your boat/trailer. Then choose the tire with proper load rating. And keep vehicle speed in mind.
Tire makers came up with trailer tires for literally one reason:
Profit.
There’s less liability because they aren’t carrying people.
The load rating is “inflated” by lowering the rated speed.
Here’s a good test:
Find a trailer tire, and a car or truck tire with a similar load rating. Or just compare specs online.
The car/truck tire will be a LOT heavier.
More rubber, more belts, more material.
235/80/16 for the 14 ply but will not fit most boat trailers. They are overkill for most boat trailers. Better for toyhaulers and heavy dump trailers. I switched over and can tell when towing there is more drag cause they are so heavy. Samson is manufacturer buy them from Simpletire.comWhat size are you running? I can't find anything.
I noticed while i had one side jacked up yesterday, the wheel would not spin freely. Normal?
No, not normal.
Brake dragging or a wheel bearing.Causes or what i can do to help it?
You want just a pinch of drag or you will smoke the bearings. But it should not be difficult. To turnOh lord. So i need to go to a trailer shop after it gets out of the boat shop[emoji34]
I had 195/65s on my previous trailer with my 27 Advantage. Boat and trailer together were right about 7k. I ran General Altimax tires, never a problem even though they’re at max load.Next problem tire size nothing available in a trailer tire only a car tire. Smallest trailer tire will not fit it rubs currently running 195-65-14 adjusted torsion axle to try and fit 205-75-14 and they are rubbing the fender on the front tire.
How long ago was this I can't seem to find to find that size anymoreI had 195/65s on my previous trailer with my 27 Advantage. Boat and trailer together were right about 7k. I ran General Altimax tires, never a problem even though they’re at max load.
So it looks like I'm deciding between the Cooper Cobra and the Carlisle ultra sport which is a trailer tire.
https://www.americastire.com/fitmentresult/tires/size/235-60-14
Ultra sport has a higher load rating and a higher price.
Opinions?
Just looked it up, must have been the 195/60/14 that I was running. I remember the 1168lb rating x 6 = 7008lb which was right at what my trailer weighed.How long ago was this I can't seem to find to find that size anymore
