Joker
- Dec 19, 2007
- 19,866
- 15,339
I'm the equipment manager on the project
Cranes, excavators ect
I just finished doing all the crack repair on the tanks. Was there since June working for Julio.
Nice, that little fucker quit a couple weeks ago
Excerpted from the FAQ section of the Edwards Aquifir site......From how I read it, it really doesn't call out actual depths. You will understand more of what they are talking about though....Hi Tex!
Do you know how deep the aquifer in Texas is that you posted about?
Curious, because I am frankly sort of shocked at the lack of current regs and studies here for the exact reasons you mention.
http://www.edwardsaquifer.net/On the news they always report the Aquifer level in feet above mean sea level. Does this measure how far down it is until you hit water at the water table?
No. Generally, confined aquifers do not have water tables. The Edwards limestone is confined between two relatively impermeable formations and is always saturated; the only place where a water table exists is near the recharge zone where there are no overlying layers (see graphic in Intro Section). The "Aquifer level" reported on the news has nothing to do with how far down it is until you hit water in the main body of the Aquifer. It is a measure of how much pressure is being exerted on water in the formation at the location of the test well. When recharge enters the Aquifer, its weight exerts pressure on water already inside. This pressure forces water up through openings such as springs and wells. The "Aquifer level" indicates the top of the water surface in the test well, which is hundreds of feet above the actual Edwards limestone. A good "indicator well" is one that never becomes artesian...water is never forced so high that it flows out without pumping. See the section on the J-17 index well for a graphic that illustrates what the Aquifer level means.
Holy Shit, worst I've seen it.
I am busy as fuck delivering the rock you guys put in these wells. One customer in Dinuba is taking 15-20 loads a week alone. 👍As most of you know, I've spent the last 30 years in the oil and gas drilling business in different capacities.
Now I am drilling irrigation wells in SoCal for the huge orchards.
There is a LONG waiting list, and what I consider pretty lax regs thus far.
These growers will pay around a quarter to a half million bucks per well, one outfit needs 45 wells ASAP.
I've been trying hard to research geologicals on these aquifers (multiple aquafers produced in each well) to find any
valid data, but it always seems to lead to bias.
But these growers are huge corporations, they would not be spending 20 million for 45 wells for a relatively small
portion of acreage if they hadn't done their research.
They are even willing to pay in advance just to get penciled in.
I'm trying to get set up with a couple of them to finance a rig and corner the market. My buddy and I just drilled one using oil field drilling practices and chopped 50% off the drilling time as compared to what they have been getting for
their money.
Point is that residential water is what needs figured out, the growers are already taking action for themselves before the State fucks their shit up worse.
I am busy as fuck delivering the rock you guys put in these wells. One customer in Dinuba is taking 15-20 loads a week alone. 
I thought you didn't haul rock.
"I" dont 
Great article that pretty much tells the story of bureaucratic political ineptitude.....
Ironically they now want to recover what they let run away......Environmentalists destroy far more than they save and are too arrogant to begin to understand it.
Nailed It!!!
Columbia River, Or/Wash boarder.....12,000,000 gal/sec to ocean in peak season....400 miles to Lake Shasta and the Calif Water system.....
Alaska...Canada...???? All Close and have the water needed.
Stay away from our water!
You aren't doing anything to stop it from dumping into the ocean- at what point is it no longer "yours"?
UD
I did add another 10,000 gallons of water storage over the winter. :thumbsup
I've always wondered....how do you keep it fresh?
Do you treat it in the storage tank, or as it flows from the tank to your faucet?
Or...?
Once it's in the ocean and in the desalination plants then Cali can have it. If we pipe it all down to Ca, when we need it it'll be gone. Why would Washington state want to inherit SoCal's inability to control its water usage?
Im not talking about tapping upstream - that water has claims on it.
Im talking about the water your state is letting trillions of gallons of dump into the ocean.
Im talking about tapping the mouth of river - there are no more claims on water dumping into the ocean.
UD
Just put a 90* at the end of the pipe & send it on down
