If you have everything do you have an Orbitor laying around?
Sorry no orbitor. have about 15 square back blanks and 2 race skis. prolly have the jigs for an orbitor.
There were some aspects of these skis construction that I would definitely like to incorporate in a play ski.
Maybe we could colaberate on something?Sorry no orbitor. have about 15 square back blanks and 2 race skis. prolly have the jigs for an orbitor.
I would love a shot at itnice maybe WW can make them work ;-)
Like what? No one uses those skis any longer do to the "modern" construction techniques. The newer constrution techniques, multi layer laminations, help with ridgidity. The stiffer the ski, the easier, and more fun, it is to ski on.
I liked the 1/4" thick top layer (red part in pics) Seems like added insurance form breaking right in front of the binding. Also the Skeg was pinned all the way through from the sides, front of skeg and rear of skeg intead of just being screwed down from the top. All in all I think I am some what ready to start doing something in the shop. I am curios about spring back when the ski is released from the press. I know when doing stair rails that you put a little more bend than you nee because of sprinback. wondering if it will be the same with a ski. If so the press will need a little more bend than what the ski will end up with. I pretty much have the construction of the press figured out in my head and am ready to try something. If you can get me that HO you want I'll give it a go. Also anyone have a line on some single layer marine ply? I can cut my own material on the bansaw but for now I would like to streamline the process and get something under you to try out.
Lets make it happen:thumbsupI have some wood here at the house that we used, ready to be thrown in the mold.
Dylan, I will make you stainless steel fins for nothin $$$:thumbsup:thumbsup
Alright, you've had a whole weekend and then some - what's the progress????????
Oz
Most likely make a mold sometime soon
Here are some pics of an Old Murdoch Race Ski. It's 78" long and until just now, i thought it was flat aside from the tip. Turns out it has a very mild rocker to it. When it's set flat, the tip and tail are about 3/16" up, while under the boots is "flat" on the table.
Looks like it was 3 layers the length of the ski, w/ an extra layer @ the boots. The extra layer starts 9" from the tail, and extends to 62" from the tail. The taper @ the back is over 7" and the "stinger" @ the front is 20" long.
The nose of the ski starts it's kick up @ 67". It is ~4.25" tall.
Just some more info, i know you aren't looking to make exact replicas, but i know this one works.
Go ahead and post up some of your findings, As far as I'm concerned getting a group consensus on all techniques will speed up the trial and error process.hello i have made two water skis e mail me at [email protected] with your phone number and can tell you what i did it is not hard just takes time
I think that what ever you guys want to try is cool, i am going to make the molds long so that i can lay up different length skis. i think that the rocker will be the biggy to experiment with once i master the construction techniques.When Dick Murdoch was making those skis, they were the state of the art. I think that not many people would race on them now days, perhaps good for kids starting out. Maha's and others start about 84" up to 88" or so.
At one time, I was going to try to shorten a Murdoch to 70" to be legal for "Pro Social" class, but the island in the center kept me from figuring a good way to do it, since the bindings would not have a full platform to mount on if they moved forward. Might be fun to build a 70" model that could be used for recreational skiing, and still allow you to try that raised island design if you designed it so the bindings could be properly located.
What do you think Dylan?
Interesting, I have noticed that the newer race skis are pretty thick, I hope to have a few skis ready for you guys to mess around on by the puddingstone deal in September.Mike Bemis has used the island design for years. You may want to talk to him as he decided to stop using it and was glad he did. This was about two years ago that he told me he can't believe he didn't stop doing the island sooner. I believe it is a lot easier to do it without the island and now many racing ski's are much thicker that I don't think the island provides any benefit.
I just saw this....bastards.
A lot of the old cypress gardens type skiis used phillipine mahogany.
I'd forget the marine grade plywood...just birch with the urea formaldehyde glue.
You've already found vacuum forming so forget the press.
I'd like to see some though given to the weight of the skier vs the thickness vs the length. It seems to me a heavier skier would want a thicker/or/stiffer ski for a reaction similar to a lighter skier.
Think through the bottom...hard maple rails...
Think through the center...more plys would be stiffer...spruce, philipine mahogony, ash...remember the old G&S skateboards? Wood and fiberglass laminated together...thin and tough
And then finish it with some excellent inlay, maple, walnut, paduak, bubinga...go nuts.
I think I'd recess the skeg plate and use a backing plate on top, but not a drop through fin.
Screws hold well in plywood...there are many and not really holding that much...a nice SS T nut would do the job though.
Sounds like a fun project...you'll need some new shaper blades for the bottoms
I have a nice taperflex...and a friend that had screw together ski handles...with a skank in the boat that wanted to use the pretty ski...
She kept letting go of the handles and the metal screw together ends put a bunch of nickel sized gashes in the skiis. I used epoxy to fill in the dings and then an exterior epoxy the refinish (recommended by taperflex).
So either epoxy or resin finish...
Hey Dylan
Everyone is telling you what you should do,, why don't you make yourself the first one as a play ski for yourself, that you can keep forever as the first ski you made?
I studied one of my mate's Maha's last night. It's a full on race ski.
The bottom is totally flat. There is only a slight taper from the nose to the tail and it is made up of 5 thick layers of Ash.
The bevel is at 45 degrees and is shaped on the bottom layer of timber ie the lamination to the next layer is where the bevel stops.
I didn't have a tape measure with me so I can't give you measurements. Can follow that up later with you once you've played around a bit anyway.
How's the jigs going??
Oz
Barry that is exactly what I am gonna do, I started on the mold the other day. I am gonna lay up a few and do different things to the bottom and play with the taper a bit and see what happens.
Oz
The jig is coming along, I cut out most of the pieces and it is almost ready to assemble. I am thinking about using some malamine for the parts that will contact the ski, my thinking is it will make it easy to scrape the excess glue off.
Got after it today, figured what better day than the 4th of July to make the mold for an American made ski. Everything went together smooth as silk. I decided that I am going to laminate the mold with Formica so I still have a little bit left to do. I am gonna lay up some Luan and make a template out of it for later. I went ahead and threw a bit of rocker in, just seemed like the right thing to do. I strapped the mold together to let the glue dry and keep everything in place. Looking forward to the next steps:thumbsup
Looks good D but I think you may have just a hair too much rocker in that thing.
I am thinking it might spring back a little when released from the mold. For the most part there is a slight rocker, and then right under the back foot to the tail it comes up a bit. Who knows:headscratch:, but were gonna find out Gotta start somewhere and for now this mold will at least let me practice construction techniques.
So????
Or is all your time going into a wood deck 10' Schiada now:skull
Im sure the concave on the bottom is going to give you some serious trouble. i have a big jig for that as well, got a good idea but dont know how to use it.
