Bringing some Facebook to Rdp
RitcheyRch
Currently Boat-Less
TrollerDave
Hope it worked for you, mine trips the breaker after about 30 minutes. Let everything cool off, reset and repeat. In the morning I'll pull out the ampmeter and see if a bad breaker or something else.
Make sure the coil is clean and wire connections are tight. Check the contacts aren’t burnt or pitted too bad. Make sure condenser fan is pulling enough air across the coil. You can amp the fan as well. Good luck and light an extra candle. 😁
