Wheeler
- Dec 25, 2007
- 24,921
- 39,178
Looking Good! Have a merry Christmas. :beer
Hey Louis, whats goin on with the oil cooler? Is that a small one down by the filter, you may want to think about useing a bigger one. Motor looks great in the boat, don"t work it tio hard I"d like to see it in Sept.:thumbsup
Not even running yet and you are already in trouble with the law!
Also, the exhaust backpressure is going to be a bitch with those plates on it!
Well I did a little work on the new mill the last couple of days. I mocked up the intake and supercharger and intake to make sure that everything is going to fit and align correctly. Also mounted the new oil filter/cooler 90* adapter.
Here is the new adapter and how it looks on the engine.
What is the reasoning behind putting the oil filter on a 90?
And where is the maiden voyage gonna be? In parker?
Here is couple of it from the sides in the boat.
Dave,
For cleaner rigging it's nice to have the filter in the stock location, but clearance is usually a problem. To make matters worse, a sandwich style adapter used to allow plubming an oil cooler adds length to the filter and usually puts the fittings coming out at an angle that requires some kind of compromise on the fitting selection of the hose.
I've never used a setup like this, but I've been looking for something similar for when my mill goes into the Spectra. The fitting placement will allow the lines to naturally fall right down along the stringer, and the 90* filter relocation negates the need for a remote filter mount. The only downside I see is slightly messier filter changes compared to a vetical mount, but I'd take that compromise for the compactness of the plumbing and filter location.
A question for FLTMVN, what diameter are the ports the AN fittings thread into? And this is for a MK IV block right?
Thanks,
Chris
OK guy's and girls here is the video of the new mill running.
Might take it out and run it later today.
YouTube
Link's not working?
It works for me. I don't know what you are doing.![]()
Louis, Did you get any more play time with the boat and motor?
Don't worry I will bring it out to kick your ass one of these days.![]()
Whatever happened to this deal, did you run it?
While your at it, you might want to recheck the depth of the dist gear as well. Actually measure it. I saw that your offset didn't have an adjustable slip collar.
