Bimini hardware
Ziggy
SlumLord
Trying to find some Stainless hardware that seems elusive. It's the quick release type that functions like a VW reverse lockout(pull up with fingers). Does not have a pin.
I have had no luck anywhere, brick/mortar or on-line:headscratch:
Any ideas?
Looks a little like this lockout:
Bpracing1127
Eddie marine, if they dont have them I have a set with base plates ill sell ya
Ziggy
SlumLord
The ones on Eddie look like what Wakebrdr94 posted........which would probably be a fine replacement for what I have.
traquer
I know which ones you're talking about, my Essex has the same thing. They're great except one side seems to always stick a bit. Look cleaner than the pins though.
KNOTONDUTY
I just ordered some from marine industries west (Dana marine) installed easy and they where sent to me within about 4 days.
Outdrive1
I might have some that I have switched out if you can't find any. I know I have base plates.
Steve-o
I had this same problem a couple years back and couldn't find a replacement as well as being told eddie marine no longer made them. Ended up changing to the newer accon quick release hinges. I believe Dana's are called "bimini flush mounts" not sure if they fit though
Ziggy
SlumLord
Yup
I'm guessing this also. View attachment 421245
Uh huh
Thanks guys. Those are the ones, just can't find them. :scratchhead:
It might be that mine are worn a bit simply from vibration. With bimini down they've popped out a few times this season in rougher water...this past weekend included. Luckily someone has been there to grab it each time.
I kinda like the function of the other ones posted so I might switch over.
Anyone know the standard size of the top tubing?
Outdrive1
Yup
Uh huh
They suck. Switch them out and never look back.
Outdrive1
Btw. I have them too. And they are through bolted. I haven't used my bimini in two years because it popped out on me. I need to take my entire interior out to swap them over. [emoji107]🏽
I even have them waiting. The tube size doesn't matter. The ends will fit on the ends you already have.
McRib
Zig my laser has what your looking for. Exactly. My Bimini mounts in 2 places. Towards the rear for transporting and top lays on the deck lid and then you move it to the fwd holes to put it up. 10 years and never a problem. Eddie Marine is what laser used 10 yrs ago for accent parts. Idk who provided the Bimini hardware though. Pretty sure they made the top just don't know where the poles and hardware came from 100%
Ziggy
SlumLord
Tube size I need because I'm going to make rear struts instead of straps. Both long and short ones.
Ziggy
SlumLord
Thanks Cop'er[emoji6] [emoji4]
They're Dana products. Makes sense, I had Dana scissor lifts put on my hatch.
Yikes $120 per set :yikes
Keys22Howie
Hey ziggy I have a brand new kit from Dana I just bought and didn't end up using. $75 let me know
Abc123
Maybe there's just debries in them and that's why they're not seating properly. Try soaking them in WD-40 or some oil for a few hours.
KNOTONDUTY
These are the same ones I ordered. Easy install.
As far as the Dana ones go this is most likely your problem Ziggy.. Get in their with a tooth brush and clean them out and they will probably work fine again. You aren't the first guy this has happened too..
I prefer the quick releases that Paul posted. That's what we put on our boat.
Ziggy
SlumLord
I'm gonna take them apart and clean them up nicely and see what happens. I do like the others ones posted better as well.
I'm guessing most stainless bimini top tubing is 3/4". Can you put a caliper to yours and see?
DeltaSigBoater
This is... Legendary!
Stainless Bimini Tubing typically 7/8" or 1" OD with .049" wall thickness.
Also get these for the rear supports
http://www.westmarine.com/buy/west-marine--stainless-rail-fittings--P018_543_004_509
Ziggy
SlumLord
7/8 is what I meant actually.:rolleyes
Been scoping the hinged clamps already and adding to my wish list:D:D
$60 is steep...found these earlier.
http://www.amazon.com/dp/B00HRIYY3W/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=5U33NM5GWTM7&coliid=I3QK3IBSRBY1NP
