AzGeo
- Jan 28, 2009
- 8,298
- 7,922
View attachment 620235 Some talk here of a blower motor being unruly at low speeds. I don't find it that way at all. I have a 548ci in my 21 Howard with a 10:71 , 2 dominators, and a fairly big roller cam, sure it surges a little at idle but I like it and with the turbo 400 it is no problem to handle around the dock using 1st gear. With a 48% v drive gear I can cruise at a fairly low rpm also, and when I want to it will hit 100+ mph at about 6200/6300 rpm. It has had some bottom work done and a 7.5 deg strut installed in a more forward location. None of these mods have caused any problems.
YEP, you know how it works, you've owned and built the boat (and others) yourself . The original question was asked by a person who does not have those kind of experiences, and my answer was directed at a person who did not specify "image" or "ambiance", just performance .
Had he said "I like blower surge", well then an EFI blower motor (any EFI controlled motor) wouldn't be what he wanted . Solid rollers, 360 lbs springs, valve adjustments, barrel valves, indexed carbs, are the NORM for many here, but some are willing to pay for more performance and less maintenance, while forgoing all the "finickiness" .
I also took NOISE as a major factor, since I didn't know if he boats in a controlled area .
Third, I must say that I still see "blower boat owners" PUMPING THE THROTTLE WHILE CRANKING THEIR COLD MOTORS ON THE RAMP .
He never mentioned COST, so knowing that an "EFI controlled turbo system" usually is at the upper end of prices, has the most docile low speed manners, is easy to start cold, makes great, smooth torque over a wide RPM range, takes minimal maintenance, and makes minimal noise, I stand by my previous comments .
In today's world of "factory supercharged, smog legal, showroom vehicles", VS the "old school" Chevelle with a 14-71 sticking thru the hood, there will always be room for "everyone's choices", just open your bank account .................
