Toolman
- Aug 19, 2014
- 476
- 752
We got hired to design and produce a socket wrench for a plastic PVC threaded cap. The cap gets torqued to 30 foot pounds. Customer currently uses a rubber strap wrench to tighten the cap. The cap measures approximately 7 inches on the diameter.
Customer supplied his own material which was cut 1/4 of an inch over finished length and 1/2 an inch over the finished diameter. I machined the front and rear faces on the engine lathe parallel and to finished length. Because I don’t have enough material to grab onto when turning the outer diameter, I moved it to the CNC lathe and friction drove it to finished diameter not hitting it too hard causing it to slip. Now I am able to grab it from the outside and rough bore the inside of the socket.
Now I move it to my TRM ( tool room mill) and cut the 12 slots that mate up to the fins on the cap and the 3 threaded holes for the driver plate.
On the driver plate I popped the three holes in the customer supplied blanks. Then I make a quick little fixture and I bolt the blanks to the fixture through the holes and mill the OD and the ID of the blanks.
I went and bought a 1 inch diameter by half inch drive black oxide impact socket and welded it to the driver plate.
IMG_4427.MOV60.2 MB
