- Sep 4, 2015
- 49,689
- 76,181
That’s all fine an good unless they are stealing his truck too.I had a fun idea...
Stow a length of stout chain / that attached very solidly to the inside of the frame up near the front of the trailer...longer the better. If you're parking it on your own property in the same spot every time....cut out the concrete and pour yourself a 16" deep footing with a low profile hook in it...sort of like an arresting hook on an aircraft carrier. Use some 100 test fishing line (hard to see at night) from the chain to another anchor point so when the trailer starts moving, it drags the chain off the little shelf under the trailer where you have it stowed so the chain lands behind the hook... Ideally they'll get up to 15mph or so before the chain hits the hook, stops the whole rig in its tracks, very likely breaking the back half of the truck off and also very likely triggering the air bags. Trailer will probably be totaled but it would be well worth it. Truck occupants will probably be a bit fucked up too.
