Nates270
- May 11, 2018
- 44
- 15
Sold my Hallett 270 and now have the following parts to sell. All prices are negotiable as I just want this stuff out of my garage. Located in Menifee, So Cal.
Professionally built 555ci NA engine. Ten hours total use pulled engine to sell the boat. New owner had an engine already. Merc 502 block, brodix alum bb2 plus heads, scat stroker rotating assembly, clay smith cam full hydraulic roller valve train, merc pan, HV oil pump, brodix intake with a quickfuel marine 850 carb Eddie marine air cleaner. Performance marine dist and wires. Comes as you see it in pics. HP estimated at 650 but did not dyno. Will come with a merc 9 pin engine harness and starter. $9k obo OR TRADE FOR HARLEY DAVIDSON MOTORCYCLE.
Aeromotive a1000 fuel pump, 100 micron filter, pressure regulator for carb with return line. Worked when pulled from my friends 28 eagle. $200 obo
Gaffrig air cleaner for standard carb $20
KE mechanical fuel pump on new stock merc pump half (have merc other half as well) $200
Hardin Marine SS raw water pump upgrade with fittings. Very little use and will throw in a new impeller still in bag. $120
Hydromotive 24P RH 4blade SS prop. Welded hub $200 SOLD
MSD Streetfire plug wires, make you own kit. Comes with wire and several ends to make custom length wires. $20
