- Sep 13, 2007
- 126,180
- 164,375
shift interrupt switches spotted:
I'm thinking not so much.. Lol
yup they're right there. good enough for a schiada!
Not a shift interrupt switch. It is there to let the PCM know when the engine is in gear to help maintain idle quality. As a matter of fact, a shift interrupt switch would be a hindrance for a Bravo shifting. They require the gear stack to be spinning smoothly to shift properly. There is a Bronze tolerance ring that is eccentric on the bottom of the fwd and rev gear. As it spins it helps force the shift fork to move the cone clutch. Mercury has never installed an interrupt switch on a Bravo application.
A little more info about the interrupt switch for your Alpha. Working properly, they only activate when shifting OUT of gear into neutral. The taper on the "dog clutches" on the gears makes it very difficult to come out of gear without the switch. When they activate going into gear, either the adjustment is off or the intermediate shift cable needs replacing.
thanks for taking the time to explain it. i love learning stuff like this.
What about shifting to drive from a 900-1000 rpm idle with an SCX4 drive?Exactly. I thought I said that only in a broader explanation. lol Keith got it.
This engine would need to idle at a minimum of 1300 to be happy with a "Dave idle". AGAIN... when shifted, the engine gets leaner. It needs a richer mixture when in gear. Richer idle mixture (not lean Dave) makes for surge. 1300 idle VERY unfriendly around docks, non-transmission drives, etc.
Dave, not poking jabs at you, but you don't understand why this engine surges. You would have to know a whole lot more about the internals of this, or any engine to say it should idle differently.
Last example: This engine will idle at 1000 (barely) with no surge. Shift it and it will die. Not maybe, it will die. A Bravo Sterndrive will weld the cone clutch to fwd gear if you chose to shift it at 1000+. (read my first response) Now set the idle at 1300 (the minimum it will be happy at a "smooth" idle) shift it, then bring me the drive.
I really did try to explain in earlier posts why it idles that way. I'll tell you what, I'll do the video Hammy suggested to show the effects of idle mixture. Then I'll fix it so it works in a boat. lol
I’m sure was the same answer 10 years agoWhat about shifting to drive from a 900-1000 rpm idle with an SCX4 drive?
Well duh haha, but I didn't see any talk about an SCX4 and we all know there's no comparison to a Bravo drive hahaI’m sure was the same answer 10 years ago
My engine doesn't seem to like anything under 850-900. And IMCO states a maximum of 800 rpm shifting. I don't have blower surge. Just trying to find the sweet spot to where my engine doesn't die when I shift into gear and not destroy my drive.Not really a big deal but like a crash box in a v-drive you shift at the low end of the surge. Most surge can be tuned out of it but higher HP stuff it’s more difficult with a roots style blower.
I assume you’re talking about a cone clutch SCX4.What about shifting to drive from a 900-1000 rpm idle with an SCX4 drive?
What kind of boat do you have?Old school = no surge.. Surge came around with political correctness and all that goes with it.
Correct. I cringe when I shift into drive haha. Have you asked TCM about it? Especially since they set it up that way. What is the motor interrupt you're referring to? Is this in the tune?I assume you’re talking about a cone clutch SCX4.
I have a cone clutch SCX with a TCM blower motor and it idles right around 800-1000. I hate shifting the drive with the idle that high but TCM set it up that way. Supposedly the motor interrupter does its thing, but it’s still a good solid thunk when it shifts.
I’ve considered adding IMCOs stand-off box that contains a transmission and getting rid of the cone clutch in the upper.
Whatever this thing is has to do with the shifting.Correct. I cringe when I shift into drive haha. Have you asked TCM about it? Especially since they set it up that way. What is the motor interrupt you're referring to? Is this in the tune?
FWIW my TCM 825 idled right at 800 and shifted in/out of gear like butter with no clunk (TCM XR drive). No stall or stumble, didn’t even change rpm when in gear vs neutral. Definitely sounds like something not quite right with yours.I assume you’re talking about a cone clutch SCX4.
Yeah I’m going to mess with the throttle plate and see if I can close it a little. The IAC if it works properly should allow the idle to be ok. I’m waiting to do that at altitude where I have the most trouble with the idle.FWIW my TCM 825 idled right at 800 and shifted in/out of gear like butter with no clunk (TCM XR drive). No stall or stumble, didn’t even change rpm when in gear vs neutral. Definitely sounds like something not quite right with yours.
usually they like shifting under 900What about shifting to drive from a 900-1000 rpm idle with an SCX4 drive?
I’m wondering if your blade needs to be cracked open more…Yeah I’m going to mess with the throttle plate and see if I can close it a little. The IAC if it works properly should allow the idle to be ok. I’m waiting to do that at altitude where I have the most trouble with the idle.
Whipple 8.3. You built the surge tank for it Shane haha.usually they like shifting under 900
Is it carbed and distributor?
I tried that on a TCM recommendation, it just made the idle come up above 1000. However, the IAC being replaced last year I can give that another try.I’m wondering if your blade needs to be cracked open more…
Like maybe your IAC is working too hard. That was my first issue and got a lot better after I gave it more blade. The rest for me I believe is in the tune.
The throttle plate should be adjusted so the IAC is barely open at idle in neutral. That gives the Iac more room to recover when it goes from load to no load. Idle speed is programmed in the ecu. The ecu will do what it has to with the iac and timing to maintain the commanded idle speed.I tried that on a TCM recommendation, it just made the idle come up above 1000. However, the IAC being replaced last year I can give that another try.
For the IAC, does that mean the plunger is almost all the way in, or almost all the way out?The throttle plate should be adjusted so the IAC is barely open at idle in neutral. That gives the Iac more room to recover when it goes from load to no load. Idle speed is programmed in the ecu. The ecu will do what it has to with the iac and timing to maintain the commanded idle speed.
Same hereFWIW my TCM 825 idled right at 800 and shifted in/out of gear like butter with no clunk (TCM XR drive). No stall or stumble, didn’t even change rpm when in gear vs neutral. Definitely sounds like something not quite right with yours.
Ah the jokes.. if I wasn’t in a meeting right now for the wife I’d be test driving an e ticket. lol.
And if my sister had a dick she would be my brother…
should be all the way in. as in closed. Should be barely a whistle out of it. You can put your thumb over the hole and if it sucks it hard, the iac is too far open.For the IAC, does that mean the plunger is almost all the way in, or almost all the way out?
Did you ground him?I love my surge once when I was off work for a while my son tuned my blown Jet tuned most of the surge out of it with boost referencing and tuning , I hated it this latest build is not boost referenced. Probably gonna leave it that way.
Motec M130.What ECU? I never saw the boat in person
Motec M130.
What you’re describing…is this retarding the timing? I was talking to Steve (Captain Hook DCB) as he has almost the same setup and he said they were having the same issue and retarding the timing at shifting helped the problem.There is some trickery that can be done by dropping the idle timing very low and leaving the initial throttle position open more, but it can be a fine line to walk when you are spraying all the fuel in front of the blower and you have no ability to get equal fueling per cylinder.
Timing is a far quicker response to a stall than an IAC is, as it can change and have an immediate effect on the very next firing event, not having to wait for the mechanical delay of the air and fuel mass to make it's way all the way down to the cylinder.
Next thing you know there will be handicap slips in the marina.When did E-ticket start making old man pontoons with cripple walker access?
Don't use the word "slip" around RD....that's what happened last time....handicap people slip a lot in the marina....gotta be careful though so they don't break their ankles.Next thing you know there will be handicap slips in the marina.
RD approvesWhen did E-ticket start making old man pontoons with cripple walker access?
RD approves
BDM touched on it in post number 52 in his first sentence... Your photo is called an "in gear indicator switch" that lets the PCM know if it's in gear or not.Whatever this thing is has to do with the shifting.
