DarkHorseRacing
- Jun 14, 2014
- 6,986
- 13,992
Sign me up. PM sent. Upland is doable.
i'd be interested in checking this out @rivermobster
i feel i'm very well versed, but i'm always down for a learning
1st class chapter 1. Bad Ground.
Chapter 2. This is a Logic Probe.
Great idea. A lot of my value as a wrench on old cars and rods, most guys are afraid of electricity.️
I actually do own a logic probe!
In thirty years, I think I've used it once.
But with that being said...
It was worth every penny for just that one diagnosis.![]()
I've never owned or used one. That doesn't mean they're not useful, I just accomplish troubleshooting in a different way. It seems like a bad idea to poke holes in wire insulation, especially in a boat, where corrosion can occur.
That would be a bad idea.
But to check if a digital circuit is high or low? It's the perfect way to do it.
I'm thinking of the 12 volt idiot light probe. Didn't read carefully.
Two words: cushion clampsGood timing as I’m considering rewiring my boat off season. Last two trips, I’ve hit a big wake and boat died. That happened 2-3 years ago and ended up being a key switch/wiring issue that would touch/lose contact. Not sure what it is this time and where to start. Having the knowledge would probably help narrow it down.
You need to properly support the wiring so if it does move, it doesn’t move much and then you’re not stressing the connectors. In a boat a bundle of wire has enough mass to flop around quite a bit.
High school they called those the magic t'sV over I x R
P over I x e
When you understand the interactions then you understand, Understand?
Do you have a syllabus? Basically what you’re covering?
Chapter 3. Keeping the smoke in the wires.
Way back in the day...
I went to a Ford training class, when the first digital dash has just come out.
The instructor is telling everyone how you can't use a test light, or an analog volt/ohm meter on digital circuits, or you'll let the magic smoke come out!
About 5min later...
He let All the magic smoke out of the test instrument cluster he was working on.
Class dismissed!
You can't put that genie back in the bottle!Way back in the day...
About 5min later...
Class dismissed!
Sounds par for the course for Ford...![]()
I'd be down 4 one of these here classes when u have space.
About 5min later...
Class dismissed!
Same here, Always up for learning a few new details.i'd be interested in checking this out @rivermobster
Power Probe. . . . . . destroying modules, ECM's, PCM's, TCM's & BCM's for 20+ years and counting. Especially in the hands of the inexperianced.Also a bad idea on a digital circuit.
