American Racing Wheels
SFV2RVR
Registered Parker Legend
fresh batch of spacers made if anyone needs any. Set of 4 shipped with hardware $200. Set of 6 $300
SFV2RVR
Back in stock.
SFV2RVR
Spacers in stock. (4) $200 shipped (6) $300 shipped. Includes
longer mounting screws.
lenmann
len this was your boat ??? jasons buddy met you at shasta
Yup, I had it for a couple of years. Drew tuned up the steering on it for me.
It was a fun boat for sure, kind of a handful around the dock, and really didn't like cold water in the spring. I sent her down the road to focus on the Schiada.
BUDMAN
HAVASU BOUND
Looks great! What size tires are they?
The tire size I'm running is 235/45R17
part# for the rims are AR VN5157865
this combo works perfect for me, however I only tow 5 miles each way from storage to launch ramp.
Hope this helps
SchiadaKev
Hope this helps
Thank you so much! That’s the look I’m going for. I will be towing a mile max so that will work.
ToMorrow44
27 Advantage TCM 800efi
I have a set of 4 of these spacers brand new if anyone need them? I bought for a project that I didn’t end up doing. $150 shipped
Reactions: D19
I’m looking to change up the wheels on my trailer. Want to do 17” Torq Thrust 2 wheel. Currently have 14” wheels with a 215/75/14 tire. Any recommendations on what size wheel width and offset? Probably going to run a 225/55/17 to maintain the current diameter tire size as what’s on there now (26.7”). Any help is greatly appreciated.
SFV2RVR
Should be a 17x7 wheel with 0 offset and 4" backspacing. I have center cap spacers in stock if you need those as well.
papabear639
Has anyone done a 14" torque thrust to utilize a standard tire size but with a cool looking wheel?
I'm running 15" Torq Thrusts on my trailer project with BFG Radial T/A's. I know it's larger than you mentioned, but I would imagine tire sizes for the 14" wheel will be somewhat limited.
D19
Hope this helps
Your set up looks great.
What size fender did you have to go to? I think mine are currently 9x66. Did you have to go wider for the 7" wide wheel?
What brand /model / tire did you go with?
I have 225/75-15 now and they rub on the fenders. I need new fenders anyways because there is damage to one from a blow out.
I'd like to go down to a 205 tire or car tire size equivalent to prevent rubbing on the fender and run the 17x7 thruster.
D19
I do have them in stock. Send me over all of your info and i'll get them sent out today for you.
Marc (818)445-6715
Do you still have these in stock?
BUDMAN
HAVASU BOUND
I honestly don't remember the size. I replace the fenders with new stainless fenders. I'll be out at the end of the month for the grandkids spring break and can get you a measurement then. I also have the old fenders if your needing a set.
Reactions: D19
D19
Thanks. I'll be out this week and can measure what I currently have too. Got the spacers from Marc on order. Need to double check my lug pattern before ordering the wheels. I hear all the Extreme Trailers are 5 x 4.5 but want to double check.
SFV2RVR
I still have 8 spacers with hardware left if anyone needs any. Thanks for the order Dennis!
Reactions: D19
