Just finished reading your thread, very nice! Who did the cover? Waterproof or just a dust cover? Do you mind sharing what it cost to have made?Had a new cover made and decided to have it cover most of the boat. Very happy with the results.
Thank you! More to come. A local guy Joe who retired from his own cover business and now does it out of his garage stitched it up. It's Sunbrella material which is very durable and more water resistant than water proof. It ran me $1,800 only because I had the material run down and cover nearly most of the boat. A standard cover from him is $900.Just finished reading your thread, very nice! Who did the cover? Waterproof or just a dust cover? Do you mind sharing what it cost to have made?
So funny you mentioned this. I was literally lying in bed convincing myself that now is the time to make the change. You're thinking the 30" tabs over the 24"?Snowball is right! I would highly consider some Dana 1100s and moving them to the outer edge of the transom parallel to the water. You are going to really increase hp and I think you will find the 22 has its limits.
I like the 1100’s because you can get kicked tails. The idea is to make flat contact with the water helping the chine walk settle down without scrubbing speed or pushing the bow down. Conventional non step v bottoms need to be trimmed out to carry the nose…. 22 offshore just doesn’t do well with thatSo funny you mentioned this. I was literally lying in bed convincing myself that now is the time to make the change. You're thinking the 30" tabs over the 24"?
I noticed the 24 Schiada's all run a 28" tab parallel with the water. I did a lot of homework on tabs the last few days. I was unsure about using a kicked tail or not. Marine Industrial is minutes from my office. I'll pick his brain.I like the 1100’s because you can get kicked tails. The idea is to make flat contact with the water helping the chine walk settle down without scrubbing speed or pushing the bow down. Conventional no step v bottoms need to be trimmed out to carry the nose…. 22 offshore just doesn’t do well with that
Coming along nice! Is Lalo the guy that Hammer was recommending in Castaic?Lalo isn't messing around. I'll prob have the boat back any day now. The last two pics show his repair skills on some unfortunate meetings with a Fox's and Roadrunner cleat. He also has a beautiful Schiada right now he is doing a full cap and interior spray. Congrats to the owner because she's going to be a stunner.
More than likely. Lalo was working out of Steve's shop in the Tajunga area. He will travel that way but does a lot of work out of his home shop in Hesperia. That's where my boat is now.Coming along nice! Is Lalo the guy that Hammer was recommending in Castaic?
PM on its way.More than likely. Lalo was working out of Steve's shop in the Tajunga area. He will travel that way but does a lot of work out of his home shop in Hesperia. That's where my boat is now.
Try MSF he builds all kinds of stuff and a lot cheaperWhile everything is out I decided I might as well update the interior/stereo along with a new belly tank. Let the snowball begin. This hull rides amazing but they tend to rock a bit. I talked to a guy with a 96 hull and said that the belly tank is a must. So I cut a big ass hole in the center of the floor. I took some measurements and I'll have a good friend model it up in CAD then have it laser cut/bent for about $300 total. Then I'll need a good tig welder. IMCO quoted me $1200 which was the cheapest out of the 4 quotes. Old set up had two 32 gal tanks. The new belly should be around 80 gallons.
I plan on opening up the interior side panels a bit more for storage and updating the front seats to a more modern look. I also need to decide if I should stick with carpet or go with gatorstep.
This was done long before I met Nick. He's already done some trailer work for me.Try MSF he builds all kinds of stuff and a lot cheaper
