8÷2(2+2)=
BHC Vic
cobra performance boats
Only what is INSIDE of them. Period. That is your 2 + 2. Nothing else.
Your argument is based on a misunderstanding of the order of operations.
There’s still a number inside!! Lol you have to get rid of the () first. I don’t make the rules :p
You can say I’m wrong but if that 4 is in () you distibute first. Why would you divide before taking care of the (). You can’t... it’s out of order
4 inside parenthesis is meaningless, it's just the number 4 itself. 4 x 4 is the same thing as 4(4). There is no operation done INSIDE those parenthesis.
8÷2 (4) is the same exact thing as 8÷2 x 4. There is no distinction. You are using a false pretext of the rules if you think that (4) means it has to come first.
The operation is already done, it's fully simplified inside the (), they can be removed at the point you have simplified 2+2 to 4.
BHC Vic
Once there is no number in front of the () you can move on
BHC Vic
Just like in the video YOU posted if the parenthesis are still there is can just go left to right
Dirtbag
Distribution is irrelevant to the answer. The distributive property is about how to multiply over a grouped sum, not about a precedence of operations. It is definitely true that:
8÷2(2+2) = 8÷2(4)
The issue is whether to do 8÷2 first or 2(4) first. PEMDAS says to go from left to right.
Sent from my FRD-L14 using Tapatalk
NO WAFFLES!!!!!! Pemdas says Parenthesis come first!!!!!!! Not left to right. So please by your own words do the parenthesis first!
BHC Vic
In this way the () never went away so we went out of order.
BHC Vic
The number inside the parentheses gets handled before the division on the left to make them go away
Go back and watch the video very carefully, at exactly 3:24 when he processes 7+9 in the parenthesis, how come he doesn't write (16) as the answer, but rather just 16.
Because the parenthesis have been simplified out of the equation, they no longer exist as an operator.
Go back and watch, you might learn something that will be important one day.
BHC Vic
And it’s all because there’s a number to distribute to the parenthesis... this is what happens when no one is ready I should already be on the water :confused:
Dirtbag
yall cant make the parenthesis disappear unless YOU rewrite the equation!
8÷2*(2+2) =16
8÷2(2+2) = 1
Stop removing my parenthesis cause you dont like them!
BHC Vic
Because there’s a symbol in front and not a number to distibute. It’s very simple :)
If you try to distribute the 2 to the (4), that would be like trying to tap a part before you drilled the hole for the tap. :p
BHC Vic
8÷2*(2+2) =16
8÷2(2+2) = 1
THANK YOU!!!
Waffles
See:
First there is not enough information present in an expression like 8÷2(X+Y) to make any determination as to any variable being equal to anything.
Further simplified there is not enough information in 4(x+y) to make any determination of equality between variables, it's an expression not an equation.
Secondly in response to your paper math, you are working out of order, that is why you are getting 1.
The proper order, for the equation written as 8÷2(2+2) is this:
8÷2(4) ->Parenthesis first
4(4) -> Multi/Divide L to R
16 -> Multi/Divide L to R
i don't make the rules, i just follow them.
If you don't follow a strict set of rules in Multiply Divide according to the order of operations, you will get into trouble like this thread is showing. Left to Right takes precedent as Multiply and Divide operations are of equal level, So to determine which ones to do first, as to not have disagreement, it is instructed that you start at the beginning of the equation and work each operation as it appears till you reach the end. Left to Right.
Parenthesis only have precedent as to what is inside of them, not what it touching them on the outside, that is where you are going wrong
If you have 8 ÷ 2 x 4 what is that answer?
By trying to distribute before you have divided you are working out of order.
Dude, if you aren't trolling at this point then i'm sorry for you.
The symbol is implied. If you choose to do math this way you will get many wrong answers and make many mistakes in the future.
BHC Vic
You have to... because the () just like dirtbag said. You can’t just lose them because you want to
BHC Vic
I know how smart you are so I feel sorry for you :)
8÷2*(2+2) =16
8÷2(2+2) = 1
This is completely incorrect.
8÷2(2+2) = 8÷2*(2+2)
the * is just a formatting change in the way the equation is written, it has absolutely no bearing on the operations.
BHC Vic
Why does a scientific graphing calculator say one? Is it wrong? Lol
https://math.stackexchange.com/questions/33215/what-is-48÷293
There is absolutely zero difference between implicit and explicit use of multiplication in order of operations aka
4(4) doesn't take priority over 4*4 or 4*(4) in order of operations.
The P in PEMDAS only applies to that which sits INSIDE the Parenthesis.
Coefficients of numbers inside parenthesis do not take special priority over any other multiplication.
So if we are to take this original equation AS IT IS WRITTEN. the answer is 16.
If we wish to format it some other way, then it is no longer the original equation.
BHC Vic
Stupid calculator waffles get your money back
you are going to be wrong a lot in the future using that thing :p
BHC Vic
Just because it’s written poorly doesn’t mean I’m going to do it wrong... calculator agrees :cool:
Waffles
Vic you should be well versed with fractions on a tape measure.
Lets treat it as a fraction... whats the answer?
BHC Vic
That’s an improper fraction. Not a division. It’s different but I like what you did there. You combined 2 numbers to make an improper fraction. Taking away the whole
Number to distribute. If it were written like this 1 would absolutely be wrong. But since it’s not...
BHC Vic
Scientific calculator says 1. Honestly that’s all I need to know.
That is literally exactly what the division ➗ sign means. The dot represents the number before as on top, and after below.
530RL
Think of this as Algebra not mathematical addition and subtraction.
As originally and poorly written.
A÷B(X+Y)
which becomes..... A÷BX+BY
Because the B is associated with both the X and the Y by the parenthesis and distributed to both the X and Y.
Now modify the equation to A÷(B(X+Y))
Which becomes A÷(BX+BY)
Now modify the equation to how Waffles did above which is (A÷B)(X+Y)
Now if you plug in A=8, B=2, X=2 and Y=2 you get three distinct answers.
And with this exercise, we can now see why the 737MAX may have a software bug or two...........
BHC Vic
A÷B(X+Y)
Now if you pug is A=8, B=2, X=2 and Y=2 you get three distinct answers.
You can do all kinds of things to modify it and change it. But my brain, like the calculator followed what we are taught. I took algebra 2 as a freshman. I’m dumb at shit but for some reason I liked math class. I enjoy this thread, like I said I don’t mind being wrong but I really don’t think I am. And the calc is the only proof I need :)
Waffles
A÷B(X+Y)
I wouldn't place the blame on 737s crashing due to glitches or bugs in the aoa sensor. I'd place the blame on boeing for letting a sociopath only put 1 aoa sensor on that thing lol
WhatExit?
As noted in post #(4*2) or ((8*8)/8) or ((4^2)/2), etc.:
530RL
My dad sent me that.
He is 81, has a Phd in Math and Physics and was literally a "rocket scientist" on the Apollo program in the US Army.
His basic answer was that depending upon what application you were plugging that formula into, you could get the answers 1, 6 or 16 all having a reasonable basis for use.
In other words, it is sloppy work product without an explanation of where and how one is using the formula and he bets the whole internet debate came up because someone used it for his/hers orals in part of their doctoral thesis.
His scribbles on the bar napkins last night. :)
BHC Vic
The whole () thing reminds me of my apprentices that’s why it makes me laugh. Example
I like math because of rules like that. For an even number you split the whole in half, for the fraction, the top stays the same the bottom always doubles. For me if I’m laying out openings and the prints give me a center. I need to mark center spilt it in half and go that distance each way. That’s how I use math now. I don’t really do algebra anymore. But math is still “fun” to me
And my scribble is on my kids coloring table :p
Waffles
The whole () thing reminds me of my apprentices that’s why it makes me laugh. Example View attachment 782442 I like math because of rules like that. For an even number you split the whole in half, for the fraction, the top stays the same the bottom always doubles. For me if I’m laying out openings and the prints give me a center. I need to mark center spilt it in half and go that distance each way. That’s how I use math now. I don’t really do algebra anymore. But math is still “fun” to me
What in tarnation..... Your explanation made no sense to me. You added all these extra steps and rules for nothing lol This is how I did it
stephenkatsea
The greatest mathematicians in the world totally agree there is more than one correct answer. They Agree? WTF - That just doesn't fit well here on RDP. Lol
BHC Vic
With the rule there is no math. For odds take one from the whole. Go to the fraction add the top and bottom, bottom doubles
For even split the whole in half go to fraction top stays the same
Bottom doubles. My point is it’s awesome to know the rule but you should know the reason it works.
The rule works great in the field because I can Do it in my head. Start scaring people if you got a bunch of math written on the floor or drywall :p
BHC Vic
Like laying out walls with degrees... why 57 5/16??? I know why :)
BHC Vic
Why is pi 3.14...
Those 3 things stay on my white board they never get erased
BHC Vic
I should probably take the time to do it neat one day. Or have one of our sisters write it for me.
