5th wheel Toyhauler tire upgrade
Dunerking
Looking to upgrade the tires on our 2020 Genesis CR28 5th wheel toyhauler..currently has Load E tires. Rim size is 16”
Thanks for any recommendations.
Dunerking
Thanks for info..should’ve mentioned our trailer came with 235/80/r16 load E.
Do you have a particular brand..i was considering moving up to a Load G..how does the Load G work going in sand and dropping pressure? Do they still float? Thanks
You can get 235/80r16 in load range g, I’m running the hankook vantara, they have been awesome and you can feel a difference when towing, the trailer feels like it glides down the road. you can still drop them down in pressure and still float over the sand no problem,
I've been running the g rated Sailun g637s for the past 3 years on my triple axle Genesis. They had a higher weight rating then others in the same size if i recall correctly. @LakeMead Boater i believe was the one that recommended/sold them to me.
As far as floating goes i don't know, I've never needed to air my trailer down, but I have unloaded my rail getting into camp more than once.
Dunerking
Really appreciate everyone’s input..going down the damn tire rabbit hole and I’m leaning towards the Hercules 901..as the are owned by Cooper and not made in Chyna. Anyone running the Hercules?
