Bigbore500r
- Apr 28, 2014
- 18,225
- 38,210
YES !OK.
He's at the mercy of the mechanic since it doesn't sound like he's capable of doing this in the driveway...
We have low compression. Low compression due to wear can't very well destroy the plugs as is being described, they'd just be dirty and fouled depending on WHY the compression is low.
If this were me, I'd perform a leakdown test on those 2 bad holes....open up the oil cap and pull the airbox to access the throttle body. With the valves closed, pressurize the cylinder and hold a piece of tissue paper over the oil fill hole...see if air is blowing out and moving your tissue paper. If not, open the throttle and hold it in front of the throttle body. If not, hold it over the exhaust dump. Air is leaking somewhere if he has 55psi of compression. If it's coming out of the oil fill, then the rings or cylinder walls are the issue. If it's coming out of the throttle body, we have a leaky intake valve. If it's coming out of the exhaust, we have a leaky exhaust valve.
If you can isolate the problem to the valves, then I'd pull the heads...if the cylinders look good, do a valve job and put it back together. If the cylinders have damage, it needs an engine (or a rebuild).
Id also ask to see the spark plugs that "have the electrode blown off" - They don't just mechanically damage sparkplugs unless some major carnage has happened. Not saying it's impossible, but ......maybe the mechanic saying "its blowing out the plugs" is his slang way of saying it's fouling plugs. And then - oil fouling? fuel fouling? Etc
