21-24 Schiada
90ish if it works and doesn't hop or have handling issues. Maybe faster if dialed.
When I was looking at building my 21 i/o I couldn't find any with bigger power to collect info. I never heard about a Schiada hopping until I started to build one and then the stories of 400lbs of sand bags in the nose and fixing the bottom to make them work started coming out.
I have exactly zero weight in the front of mine. You can put whatever prop on it and trim it to the moon and back and you won't get hop. It's all in the setup.
You are right though, most (not all) the I/O schiadas need a little help in the setup department.
Cole Trickle
Sounds like your wham-o plate and rudder rocker is working like a charm[emoji12][emoji41]
I think the weight of the sbc helps as well
lenmann
What is "hop" as it relates to this discussion?
Kylemenz1
Buy that yellow 24, redo the interior, and out the BoostPower 800"er in it.
Schi-502
My Schiada is still for sale.
Mark
707-372-1741
Riverbound
Well, He did say big power schiada. And that's just a club you aren't a part of.
X Hoser
Tony bought a 21rc two days ago. [emoji106]
That 24 is pretty nice but has a 330hp 454.
Post it up Tony. What did you buy? :) I know it's either amazing or will be amazing when you are done with it.
tony
Unbelievable I've been looking for months even years and the minute I strike this pops up!!! Great looking boat perfect starting point!! I wonder if it's a delta pad bottom?
jstnoc
Let us see what you bought Tony?
aaronschiada
I know....and I have pics....hehehe....but I'll let Tony do the honors! 👍🏼👌🏽
tony
I bought the boat from the original owner with 26 hrs on it! It has an all aluminum 600+CI big block with 18 degree dart big cheif heads dry sump oiling deal. I've always liked this boat and it's set up with its big inch set up with no turbo's or blower. I'm going to do my anal shit to it and try to enjoy it!!!?
jstnoc
That's a nice piece Tony! Congrats! I always liked this paint scheme and the cap makes it looks even better.
overpriced hallet
:hmm Tony, a painted oil cooler and a cast manifold :point where do you find this junk:D
Ouderkirk
It's a beautiful boat...congrats. :thumbsup :thumbsup :thumbsup
I am intrigued by the all aluminum BBC. The weight reduction to the equivalent to a cast iron SBC should change the handling characteristics significantly. That's like a 300Lb weight reduction from a cast iron BBC.
I've considered the all aluminum BBC thing, but you read about how the sleeves float in the castings and other weirdness related to the aluminum block, it certainly makes an amateur like myself take pause before you shell out serious $$$ on something like that.
Keep us posted on your thoughts about the overall reliability of the all aluminum engine and how you think the handling is different from an iron block.
28skater
Nice a new Schiada build:thumbup: is the drive train at Brummett's yet?
tony
The difference is about 180 -200 lbs compared to a cast block. I'm sure motor placement is key in any set up as far as weight is concerned.. Hopefully I don't have any problems with the motor if I do I will build a new one.. The guy who built the motor has held offshore records and also built motors for Indy cars such as Mario Andretti,AL Unser sr,Andy Granetelli and a few others. His motors have finished second place at the brick yard which I think is pretty good... He also did all of GM'S high performance stuff for almost 20 years and the motor thats in this boat was originally built for Gm.. He also builds a lot of airplane racing motors for P51 planes you can google his name and check out the stuff he's done It's pretty cool. RYAN FALCONER
tony
As soon as yours goes and gets Brummett power mine will be behind you! I've always wanted this boat so we will see how she does...
X Hoser
Tony, got your email. Very nice, can't wait to see what you do to it. Love the colors! Kinda like your old 24
AZLineman
Adjusting to retired life
Bitchen set-up! Congrats. If you take the exhaust manifolds off sometime I would luv to see the port adapters/spacers. I have a similiar big chief set up and have pondered the limited exhaust choices.
28skater
Ok where is the progress photos Tony? You are only Schiada re-rigg keep us up to speed, Im thinking new Platinum gauges, plumbing SS fitting and 3rd axle for the warm up run .:thumbup:
Im sure you stole the thing raid the wife's shue box:thumbup:
