20’ Schiada interior build.
whiteworks
Custom Shutters by WhiteWorks
I did this about two years ago for a friend here on the boards. I was just tasked with building the wood base work for the apolstry. The original seat was just one like drivers side and then a wrap around deal on passenger side, I was asked to mirror drivers side. I think Arko did the apolstry work, it turned out very nice. Apparently Schiada was years out so it came across my plate. I don’t know how Schiada does it, but this is how I do it LOL
mbrown2
Sick! ....initially I was thinking why not use coosa board...then I slapped myself and thought this is craftmans stuff!
lenmann
Ooooh, now this is some interesting and timely content, thanks for posting it up.
Can you share some details on the curved back kerf cuts and lamination process?
Also, what thickness and grade ply did you use?
whiteworks
Baltic birch plywood is unique because of its all-birch veneer core that's cross-banded and laminated with exterior grade glue, making for a superior stable sheet. It also has a thicker face veneer than traditional cabinet grade plywood.
whiteworks
Not sure what details you’re looking for, it’s just relief cuts and lamination based on my judgement of what I wanted it to do. 13 ply Baltic Birch was material used.
Interesting that you laminated 2 pieces on the curves....I typically just do the one piece (the first piece you did (and then once it's tacked in place, fill the cuts with some thickened epoxy and throw a layer of 1708 over it, then of course glass all the corners/seams.
How heavy did those end up being?
whiteworks
Maybe 25lbs more than original, if it was a stoker I would have went with less durable weight saving techniques.
Jay Dub
View attachment 1220314 View attachment 1220315 View attachment 1220316 View attachment 1220317 View attachment 1220318 View attachment 1220319 View attachment 1220320 View attachment 1220321 View attachment 1220322 View attachment 1220323 View attachment 1220324 View attachment 1220325 View attachment 1220326 View attachment 1220327 View attachment 1220328 View attachment 1220329
looks great. thanks for sharing
Baltic Birch Ply is so nice to work with
I don't do very much wood work, but i build these carts a couple years back for the shop and made all the drawers out of Baltic Birch. Just easy to work with, nice and flat, cuts well, etc
lenmann
Two layers of 3/8" with facing kerf cuts? What adhesive did you use? Did you resin coat everything before the foam and upholstery went down?
whiteworks
Those are sexy work carts👍
whiteworks
Tight bond III for layup and all joints, I didn’t resin coat it, but it was resin coated prior to upholstery be applied. Those bucket seats are crazy strong, I wouldn't hesitate to put some big dudes in them and bash the Parker slop of a big weekends for years. If those seats break, other shit will be more broken😂
retaocleg
all that work, dont cover it..........rather see it stained and cleared, or just cleared.....vinyl wont protect anything
retaocleg
i meant the under side and normally exposed stuff......didnt mean dont upholster......i am an ass, but not that much of an ass.....wife will contest tho
i hate that netting stuff some put on the backsides
