Toolman
- Aug 19, 2014
- 481
- 776
Check you out! Building tooling and all! Great work!
Looks like you nailed it dead on. Good work.Thanks for the positive feedback guys, much appreciated. By the way if you see me doing something wrong, don't hesitate to pipe up, constructive criticism welcomed on this deal. As mentioned above, this is my first time down this trail.
Next up, the prop shaft hole. The hole's location is set by the bushings in the barrel of the strut and a really long hole saw. Assuming I got the strut in the right spot the prop shaft hole should also intersect the imaginary plane through the V of the hull and pop out of the floor on the centerline I taped out.
Not having anybody nearby to borrow a really long hole saw from I made one using my old 1" prop shaft, a carbide tipped 1 3/8" hole saw a piece of 1 3/8" thin wall tubing.
View attachment 996121 View attachment 996122 View attachment 996123
I made up a plywood guide to help avoid any "walking" from the hole saw as the hole started holding it up against the hull with a floor jack. Everything lined up well with the marks I laid out using the laser pointer, so I clamped on the electric drill, took a deep breath and pulled the trigger. The drilling took less effort than I expected and went pretty quickly.
View attachment 996130 View attachment 996129 View attachment 996131
I don't have my new 1-1/8" prop shaft yet because I needed to drill the hole first and mock up the v-drive location to figure out the length so I can order it from Bergeron. I ran down to the local steel yard and bought a nice chunk of 1-1/8" cold rolled steel (have you seen the price of steel recently?) and after installing the bushings in the strut, shoved the bar up through the floor and the shaft alignment came out pretty close to perfect but you can see the shaft hole walked about an 1/8" to the right. I'm not really sure why. It may have been a little misalignment of the plywood "V", maybe some slop in the strut bushings, or in the interface between the hole saw and shaft. I am pretty sure it will be OK, there isn't anything close to interference with the shaft and the shaft log flange is large enough to assure everything seals up well.
The slug from the hole saw is pretty cool, feels funny cutting out some of glass I put in there not so long ago.
Next up: Rudder stuffing box, blast plate, and the motor rails and million other things...
Nice work len, I used to call those a tube saw. Hang on to it, they come in handy.Thanks for the positive feedback guys, much appreciated. By the way if you see me doing something wrong, don't hesitate to pipe up, constructive criticism welcomed on this deal. As mentioned above, this is my first time down this trail.
@lenmannMade some progress since the last update. Spending a lot of time drawing up parts and waiting on machine shops.
View attachment 1000019 View attachment 1000020
I took a page from the @Backlash best selling book "Saving Wood Transoms for Fun and Profit" and wound up some fiberglass tubes for the drain plug and through hulls. I bonded the tube and some glass plugs that were then blind drilled and tapped to assure a leak proof finished assembly. This should do a better job of water proofing than gobbing a bunch of silicone on the fittings and screws. If you have ever lived the absolute HORROR of replacing a rotted, waterlogged transom this relatively small amount of extra effort is cheap insurance. I will do the same for the raw water pickup through hulls once I figure out their exact locations.
View attachment 1000009 View attachment 1000010
Also drilled, trimmed and set the rudder stuffing box, set the blast plate, and got the motor rails drilled and set. As you can see, I went with two pieces of 3/8" aluminum angle as Schiada isn't selling any Z extrusion these days. I think the Z rails are a more elegant solution but the aluminum angle approach will be plenty functional and strong. Note the sooper cool engine plate mounting blocks from @Toolman
View attachment 1000013 View attachment 1000015 View attachment 1000016 View attachment 1000014
Next up, cav plates, motor plates, clamshell braces, and a start at roughing out helm, seat and pedal positions.
Im curious, did you drill the stringers, motor rails, and backing plates all at once in the boat or separate on drill press/mill? If done in the hull, how did you keep everything strait and clean?
I have a project that is going to need rails and maybe backing plates but my stringers are already drilled, not that I couldn't plug and drill new holes, but, it will be a new experience for me.
Killer progress
They are 1/2" diameter x 1" long G-10 epoxy/glass cylinders bonded in a slightly oversize hole with thickened resin. When I cut them off on the lathe I added some grooves to improve retention and bite. I pre-fill the hole and paint some resin on the plug and when inserted the surplus resin and air squeezes out and fills the gap between the plug and the hull. The plugs finish up little proud of the adjacent transom surface so I carefully grind them flush, drill and tap. The flange on the Teague drain assembly just covers the plugs so it worked out pretty nicely.@lenmann
So I have a question on the drain hole and glass plugs for the screws. How did you bond those plugs to the gelcoat? Do you have to feather the gel back a little to get them to “bite” and seal up good or do you just epoxy or resin them in place and grind/sand them down flush?
Once the epoxy set up I drilled through the holes in the inside rails through the stringers.
I hope that makes sense.
Yup, I follow. Was any jig used to keep the drill square going through the stringer? I have through drilled a stringer once and it didn't end up level
Tooling!Yes, I just made up a simple MDF jig using a 3/8" drill bushing I had laying around. Inserted the shank of a 3/8 drill bit through the bushing into the existing hole, clamp the jig, remove the bit and drill away.
I am no Tool Maker but I have made some tools.Tooling!
Seriously though, I have this box of drill bushings of all sorts of sizes and shapes. Something I probably scavenged from a job 40 years ago, stuff that got pulled out of tools before they were scrapped. EVERY time I go to that box hoping to find the size bushing I need for some random project that needs a straight hole, there isn't one."I just happened to have one laying around...."
Final coat of Duratec VE primer on and the guide coat applied. More sanding...this time with 180 grit.
View attachment 874551 View attachment 874552 View attachment 874553 View attachment 874554 View attachment 874555
Happy with the way the strakes sharpened up.
View attachment 874556 View attachment 874557 View attachment 874558
Shot 3 + gallons of Dura-Kote Tapeline White gelcoat. The first 3 coats mixed 70:30 with DuraTec Clear High Gloss additive to build opacity and the last two coats at 50:50 to get to a 30 mil thickness. The additive helps the gelcoat spray better, flow out with less orange peel and best of all eliminates the need for an air inhibitor like wax in the gel coat or PVA sprayed on afterward. I used this combination on the finished bilge of the DCB Mach 22 I recently sold and was pretty happy with the results. It laid out smooth enough that I didn't need to sand or polish it. This time I really had trouble getting the gel to lay down and flow out. I used the same gravity feed HVLP gun with a massive 4.5mm air cap but at the 70:30 mix it went down a little dryish and didn't flow well, the 50:50 batches sprayed and flowed better but because the base layers were lumpy I ended up with more orange peel than I wanted that will require some extra sanding. Oh boy! Turns out this gel coating deal has a bit of a learning curve.
View attachment 874560 View attachment 874561 View attachment 874562
May I ask what final sanding paper you used for the primer before gel? Also what gun did you use? Thank you.
IMO the painted fenders are look way better. Everything is looking awesome! This thread is a wealth of information sir! Thank you for taking us along on this process!Well, I'm back on the Schiada after a bit of a summer lull.
Made a late July banzai run to SoCal to pick up new fuel tanks at Imco, zipped over to Phoenix to grab my prop shaft at Bergeron, and then up the Havasu to get my new trailer at Adrenaline.
The trailer was supposed to have stainless fenders but after waiting almost a year, I gave up. To be clear, this wasn't an Adrenaline issue but a problem with the company (Rockwell division of Lippert Inc) that acquired Fenders and More, Adrenaline's long time fender supplier. Rockwell moved all production to their Texas facility, shut down the LA operation, and failed to retain any of the people or knowledge required to roll stainless fenders. Adrenaline has committed to swapping out the painted fenders once they can get a set that meet spec and look good.
Mandatory stop at Terribles to load up on energy drinks and junk food for the long haul north.
I am digging the transom blocks!Back on to the cavitation plate set-up.
First up, I needed to get the shaft arm mounting holes drilled through the transom, in the right location, and drilled perpendicular to the transom face. I used the laser cut back-up plate as a drill guide, shimmed it up to the right height, centered it and then clamped it in place to drill the holes.
And best of all, when I moved the plate inside the holes all lined up!
So I mounted up the left and right arms with the shaft leaving the center arms hanging so that once I tightened down the outside blocks I could rotate the inside ones to see how much would need to be trimmed to compensate for any crown or deviation in the face of the transom. The idea here is to have the bores in the arms aligned well enough that the shaft turns freely by hand one all of the arms are bolted down.
So, somehow I got really lucky and all four blocks flipped into place without any machining. Once I pulled the blocks tight I could rotate the shaft easily by hand. Maybe the big piece of channel iron I used when I clamped the transom (back in 2019!) really helped keep things straight!
Next, I was able to bolt on all of the plate pads and pin the turn buckles in place to confirm the CAD model and specifically the hole locations on the shaft. I had to make a couple of small adjustments; I am guessing because the hull might not be exactly 15 degrees at the vee, or the pads might not be exactly 15 degrees at the base, or a little bit of both. In the pic you can see the two innermost turnbuckles kind of splay out at the top. Some of this was just tape I put on the plates to protect the surface but there is some geometric difference between what I drew and the hull in the real world causing some of the splay.
Off to the Bridgeport to drill and spot face the holes for the upper turnbuckle mounts.
And reassembly. Super happy with the way it turned out.
Jus got my fenders from fenders & more !!Well, I'm back on the Schiada after a bit of a summer lull.
Bummer on your fenders, its hard to believe how screwed up Fenders and More is currently. I visited Adrenaline 3 times during the build on my trailer an each time they had a new pallet of fenders that didn't meet dimensional spec or had workmanship issues. It had a major impact on their business but appears to be stabilizing recently.Jus got my fenders from fenders & more !!
Ordered them Feb 1st of this yr !!! Finally got them and they don’t fit ???? Bummer !!!
What size wheels and tires do U have ? The fenders look pretty wide ! 11” ???
The beautiful flange weld is Teague's work, mine, while functional aren't nearly that pretty. If I had to guess I would say yes on the positioner though, the spacing is perfect and there are only two starts.Did you weld that tube on a positioner?
