Eliminator21vdrive
- Jul 5, 2016
- 1,955
- 3,749
Nice work as always.
What is in the strainer?
Thanks,Nice work as always.
Great question, and milling more clearance on the tiller was my first thought. The next problem was the 50 degrees of port rudder and only 30 of starboard rudder rotation. Could I have got away with the imbalance? Maybe, but it would have gnawed at me every time I drove it.I’m probably over simplifying this and even though your pictures are always great I’m probably missing something but based on the design of the tiller could you of just clearenced the edge of the groove for the cylinder shaft and just repaired the cylinder its original configuration or based on tiller design, cutaways, etc, it would not have left enuf material for strength? I hate thinking about the stress bending that cylinder shaft put on the end of the rudder shaft during the bend process
Thanks.Again great write up and thank you for sharing your challenges also! I wish you had pictures of the repair process! What kind of machines do you have? Everything you have done has been extremely impressive!
It had been a while since I had cut any single point threads so there are a couple of aluminum practice slugs laying around now. Getting the timing right on the tool retract was tricky. But remember your setup had dial indicators all over the place, and that worked well. Kinda weird watching the indicator and not the tool. Gotta "trust the force".On the last couple i have done i actually keyed the rudder off center and clocked the tiller so that when the rudder is straight the tiller actually looks like it is turned pretty far, this way i get ideal swing for where the constraints of mounting the fixed end of the ram is.
Picking up single point threads is a little daunting the first time you do it, but once you have a system down it works very well.
Also those imco rams are heavily polished so before you even start you either need to use a 4 jaw or offset an adjustable chuck to get everything running concentric. Lots of time spent getting it all setup to actually do the cutting.
Good save that could have been very catastrophic.
Bummed to see this. At least it didn’t seem to hurt anything else. If trying to pick up that thread and cut it deeper make sure to account for slack in the screws on the lathe. It’s a do’er but a little tricky. You can always put the machine in gear with it off and turn the chuck by hand during set up to check it. Also, making those cylinders is not too hard either so if it doesn’t work on the threads you could just make a new barrel. You got my number if you want to bounce some ideas off.Thanks.
I am rocking an old Leblond Servo Shift and a Bridgeport with a variable speed head (that needs some love).
Can you post up a pic of that tiller set-up. I cant quite picture it in my right angle symmetry oriented brain.
Thanks
Racey, unfortunately that rudder is already keyed and 1/2 holed for one of the tiller bolts….if I remember right.On the last couple i have done i actually keyed the rudder off center and clocked the tiller so that when the rudder is straight the tiller actually looks like it is turned pretty far, this way i get ideal swing for where the constraints of mounting the fixed end of the ram is.
Thanks.
Thanks
Needless to say I was bummed too, but the good news is the recovery was relatively painless, just a bit of extra work.Bummed to see this. At least it didn’t seem to hurt anything else. If trying to pick up that thread and cut it deeper make sure to account for slack in the screws on the lathe. It’s a do’er but a little tricky. You can always put the machine in gear with it off and turn the chuck by hand during set up to check it. Also, making those cylinders is not too hard either so if it doesn’t work on the threads you could just make a new barrel. You got my number if you want to bounce some ideas off.
Yes, you are correct on the breather. I ran a line from the vent on the upper cap on the drive to the puke tank which is seen on the left edge of the third photo. The intent was to capture any oil spray instead of it venting out the top. The cap on the tank is vented to atmosphere. I still need to consider getting cooler water to the drive. I could pick up water right off the cam driven water pump before it heads into the motor.I love seeing pictures and video of this boat! We run a 3 blade now that the boat is a cruiser and used to run a two blade for racing. Less vibration for sure. We run our water inlet for the Vdrive from the trans cooler which is on its own pick up. So trans and Vdrive are own its own cooling set up. We can always touch the Vdrive by hand to make sure temps are manageable. Forgive me because I cant see much with the pictures, but isn't the top line out of the Vdrive for a breather?
Hopefully it is a simple fix! What an amazing build!
I also learned that I should have brought my infrared temperature gun with me. After I was satisfied that there weren't any issues or leaks back in the engine/trans area I noticed that the v-drive was pretty hot, like way too hot to touch hot. I have the cooling lines to it running off the exhaust manifolds as that was the cleanest place to get pressurized water headed in that direction. I need pressurized water for the PSS shaft seal. The motor was running at 140* which surprised me a little, I had expected it to be running a little cooler given that I was wasn't really putting much load on it. I was getting pretty worried about the v-drive temp so I texted my buddy to grab the truck and meet me at the ramp to load her up. So I am cruising back at about 25-30 mph, taking it easy, and about a 1/4 of a mile from the ramp I got a big old whiff of stinky gear oil, I look down and see a growing puddle of turquoise Redline Lightweight Shockproof Gear Oil on the floor under the v-drive. I killed the motor, grabbed handful of rags and tried to see where the oil was coming from. The v-drive was hot A/F so I was thinking I must have burned it up? But with a rag wrapped around the coupler (it too hot to touch also) I was able to rotate the prop shaft so the bearings weren't bound up or seized, it was just crazy hot and barfing oil. I couldn't really see where the oil was coming from with the driveline guard, strut rods, and seats in place so I did what could to contain the oil spill and idled back to the ramp with a new mystery to solve.
My boat is setup a little different than what you have planned, I think.Lenmann, I am going to be running a similar water routing as you from the intercooler to the oil cooler and vdrive water cooling.... I haven't ran it this way yet, but my thoughts are the water coming out of the intercooler might be hot and cause everything else to heat up prematurely. I was debating putting a T fitting before the intercooler and splitting the water. One route would cool the intercooler only and the other would cool the oil cooler then the vdrive.
If possible it might be worth it to get a temp of the water exiting the intercooler. I'd be curious to see what that # is.
The tunnel cover sits on alumnium angle brackets mounted on the inside of the stringers. It also ends up kind of locked in by the seats once they are installed. I hadn't planned any fasteners but can add them later if it moves around too much. Both the floors and the tunnel will get snap down carpet.Beautiful as always. How is the floor getting mounted?
Thank you for the updates
Holy crap! You’re wild!! WowNext up is the hatch, this turned out to be way more work than I thought…kinda like the whole project.
I was a little jammed up on what hinges to use for the hatch. Stan at Schiada uses a shepherds hook style hinge that pivots above the transom on a glassed in support. If I recall correctly the setup was created by @BamBam way back in the day when he was employed at Schiada rigging boats. I am long past being able to glass any additional stuff up above the inside of the finished transom so I needed to find another solution.
I bought a couple of sets of Camaro and Mustang side mount billet hinges from Summit (liberal return policy) but didn’t really like the way they looked or fit up on the boat. In one of my failed scheduling calls with Conquest I asked what they use and they turned me on to the hinges that Marine Industries West makes that are hydraulically actuated with a trim pump. MIW will also make them without the hydraulic cylinders for electric actuator applications like mine. They are beefier than the car type units and side mount to the gunwales and face mount to the bottom of the hatch. Like everything MIW sells they are really nicely machined units, polished and clear anodized to match the rest of the hardware on the boat.
View attachment 1334640 View attachment 1334621
Once I had the hinges and a rough idea for a hatch design and shape it was time to start mocking up some stuff. I wanted the hatch to be as low as possible and smooth topped without scoops over the carbs, but turbo motors, while not as tall as blower motors, are still tall. I am using 2” tall flame arrestors on the carbs which gets them down to the same height as the intercooler so those points set the basic shape for the front of the hatch. The aft edge is just scribed to match the top of the transom. The trick is figuring out the shape of everything in between. I wanted less of “hump back” look than some other hatches I’ve seen so the shape I landed on was more of a “fast back” look. When I rigged the motor I set it as low as possible to keep the hatch height low. Once I figured out the front to back shape I cut the spars that finished the support structure under the deck and glued/screwed them to the perimeter frame. As you can see in the pictures I cut pockets for the stud plates to mount the hinges as well. As I think about it now, I wonder if running a dry sump could reduce the oil pan depth, lowering the motor? It would create some interesting driveline geometry as the v-drive is already on the floor. Maybe on my next Schiada resto (hah!).
View attachment 1334639 View attachment 1334635
View attachment 1334634 View attachment 1334633 View attachment 1334632
Now we have a non rigid frame that defines the edges of the hatch and the profile of the center section front to back. I needed a way to create the curves that transition from the front profile to the rather flat aft profile at the transom and to be repeatable from side to side. I modeled the hatch structure in CAD by manually laying out measuring points spaced 1” apart at the front and rear of the hatch measuring the vertical height across from gunwale to the centerline. I recreated the same set of points in the CAD environment, drove a spline curve through them that mimicked the shape of the hatch frame. Doing the same with the front to back profile gave me enough information to loft the full shape of the skin of the hatch. (note: check out the @RiverDave Eliminator tour thread, this would have been much easier with a 3d scanner!) I could the tweak the loft parameters to get a shape I thought looked best, would clear the intercooler and carbs and conform to the edges of the gunwales and transom. By cutting cross-sections though the CAD modelled hatch I could reverse the process and create staged supports that replicated the shape at measured intervals from front to back assuring that the hatch was the same side to side. These stages were temporarily attached to the frame with screws and hot glue. Now I have a framework in the physical world that represents the desired shape of the CAD model that I can apply plywood to give the hatch skin. One important thing I had to remember is to allow for the thickness of fiberglass, coring, upholstery materials, and gelcoat at all the interface surfaces between the hatch and hull, carbs, intercooler, etc.
View attachment 1334649 View attachment 1334630 View attachment 1334631 View attachment 1334629 View attachment 1334665
The next challenge was how to bend ¼” marine plywood to conform to the complex curved surfaces. The center section was pretty easy requiring a handful of kerf cuts to make the bend in the middle work but as you can see in the pictures plywood doesn’t like bending in two directions so a couple of additional cuts were needed to get it to pull down for glue and staples.
View attachment 1334670 View attachment 1334669 View attachment 1334668 View attachment 1334667
The side surfaces get pretty complex from a curvature perspective, not only bending from to back but going from a tight curve at the front to almost flat at the back. There just isn’t any way to make a sheet of plywood conform that way. As it turns out wooden canoe builders solved this problem a century ago using thin wood strips edge glued and nailed over a framework to simplify creating complex shapes. Keep in mind that my plywood surface will be laminated as a core between layers of 1708 fiberglass which will provide most of its structural strength. Additionally a layer of ¼” balsa core will be laminated on the inside providing substantial additional structural integrity to the hatch. Even with strips as small as 1” wide it was challenging to get them to twist enough to conform to the stage supports. I ended up ripping kerfs lengthwise on the bottom of the strip to get them to free up a bit. Once I had it all laid out its was a pretty simple process to edge glue and staple the strips to the frame. I used cabosil filled vinylester resin for glue and stainless steel 18 ga. staples.
View attachment 1334626 View attachment 1334624 View attachment 1334625 View attachment 1334680
fter the adhesive cured I lifted the hatch out of the boat and onto the bench to start the cleanup and lamination process. The top surface needed some smoothing to address the edges created by the ply strips and a little bit of filler here and there. Once I was happy with the surface it got a single layer of 1708 and V/E resin. Because this surface gets covered in foam and vinyl there won’t be a need for final finishing, gelcoat, etc.
View attachment 1334622 View attachment 1334664
I trimmed the excess glass from the edges and flipped the hatch onto a mobile cart I built to be able to easily move the hatch around during the next phases of construction. Once flipped over I removed the stage supports and started laying out the balsa core. I also decided to fill all the kerf cuts will cabosil/resin to assure I had a nice consistent surface to bond the balsa to.
Next chapter: Balsa, balsa, balsa
It's an affliction for sure, therapy has yet to help.Holy crap! You’re wild!! Wow
As always you are doing fantastic work!Next chapter: Balsa, balsa, balsa
I committed myself to a comprehensive build thread here on RDP so that others could make better informed decisions about their own projects. I have tried to be transparent by including both the successes and the mistakes. Don't let anybody fool you, lots of the techniques used in restoring an old boat are hard to master and mistakes are both time consuming and expensive. Part of the joy for me personally has been learning new skills and adapting skills that I already had to this project, and I just like working with my hands making things.
@HydroSkreamin "How far apart are we geographically now? I'm in the Phoenix area."We are way closer geographically now than ever before. I'm up in Northern California, near lake Shasta. That said I am going to be down in Goodyear AZ the week of February 26th and was thinking about dropping in to meet you in person and see the new DCB digs.
Thanks!@lenmann
Len, I knew you had a schiada you were working on. I believe I joined rdp sometime after you started this thread but until just the other day I had not been aware of your build thread. Wow! Reading this has been like a good book I couldnt put down! Literally, I have gotten in trouble with my wife because I'm immersed in reading and not paying attention to her and nearly been late to work several times because I've lost track of time. It's taken me nearly a week to get caught up because I read the write up, look at the pictures, go back and read it again just to make sure I'm understanding it all correctly. Your planning and execution of every detail is incredible and your humble attitude towards it is awesome. Way to go sticking with it especially when things didnt go like you'd hoped. Guys like you are motivation for me to grow and get better. Thanks for a great read!
Side note, share some info with me about that cav plate switch and slip ring deal on the steering wheel?
