05 Ram/Cummins
Anyone have a good source for a rebuild or long block. I’m coming up on 300 soon and want to be r
my timing cover is leaking and I think it’s blow by related I’d hate to spend 1500 to fix it all to find out it blows out again. I figure put that money toward a rebuild. I have the usual valve clatter lol.
Pull the oil fill when it's running and warm, that'll let you know if it is major blow-by. The front timing cover shouldn't be that much, but the timing case behind it sucks. I think from the factory both had paper gaskets.
My old 24v had 960k+ on it. Very little blow-by. That was also an early 6spd motor before they "made it better" for smog. A few of my friends are running late motors between 3 and 400k, and seem to run into leaks. A friend currently has his apart doing the o-ring between the adapter plate and block, behind the cam. He thought it was his oil pan. 10hrs later, nope...
petie6464
Replace as many expensive parts as possible then trouble shoot. .
Most likely injector wiring harness issue as other mentioned..
Brokeboatin221
Right on good to know. Do you work on these things?
OCMerrill
All in...
This is the next challenge for us. We have the same leak and it has coated the underside bigtime over the last couple years.
Still better than a $1000 mo payment.
When we pulled the rockers off there was no visible signs of wear. There is a guy on youtube, a hotshotter PD DIESEL maybe. He runs those 6.7's well over 500k and then sells the trucks. My 04, now my son's, with zero emissions outside the engine anyway, 49 state truck with no CAT, I feel is worth dealing with.
Been forced to learn. First with my own work trucks, now as partial income on others work and ranch trucks.
Oil pan isn't real bad, just have to remove and reinstall the pickup halfway through the ordeal. Still cheaper than one payment on a new truck.
Brokeboatin221
If you’re up for some side work Pm me your number.
Gelcoater
To the guy you were quoting here.
If you don’t have any blow by the Stealership quoted me about $1,400 to do my front main seal.
It may or may not be worth your time to do it yourself?
I’ve done the water pump on this truck.
It was a 3ish hour job at a lazy pace in my driveway.
I’m not sure I would do the main seal job in my driveway?
Gelcoater
His language may be way off the wrong way?
But I have some respect for Omeril doing his injector job at home himself. 👍
I have a few factors involved in the do it yourself or pay department.
First, I am a rare combination of both poor, and cheap. If a repair costs more than my first house payment, I'll try and figure it out.
Second, I have little fear of diving in way over my head🤣 The way I look at it, some guy assembled it, I can figure it out. No matter how you look at it, it's just nuts and bolts. The details of electronic parameters on the fuel control can screw with most people, but once that stuff is out of the way, not too difficult. Piston engines have been around a long time, so the concepts aren't anything new.
Third, YouTube is handy for stuff. Someone else has broken the same thing. Even if not to see how they repaired things, to see what can of worms you're opening.
At 1400 dealer cost, the first thing I'd do is see what their labor cost is. If it's 150-200 an hour, and it may be 1-200 in parts, you can guess how many hours they figure. It's a good baseline to establish time.
I'm in the middle of AZ, and my big projects have slowed. Dave's project is waiting on paint, and I have a 33 needing attention. Lately I work about 3¹/² hrs, mornings, at a shop down the road. A lot of my time during daylight hours is spent shuttling kids for sports or for appointments.
Xring01
I have heard repeatly from all of my buddys who owns Ram/Cummings… 1 Million mile motors…. Blah blah blah…
Hearing lots of problems on this thread…
What are your expectations of your Ram Cummings ????
Brokeboatin221
Never heard of a Cummings 😂. Problems come about after 288k of hard miles and actually using a truck. It’s also 18yrs old so I can’t really complain. No payments and when I have small issues I replace things with better parts or factory parts that made it the 288k.
endobear
Damn motor has to come out or get loosened up and lifted way out of the way to do an oil pan on a 7.3. And its the 1st thing to rust out on my old girl.
Yep...almost easier to pull the motor and reseal everything😁
OCMerrill
All in...
Pull your pants up Bill Sparks.
BTW I am well aware I am off the wrong way. 😁
I did the first two, Evan busted knuckled the remaining four.
sintax
@Gelcoater So, I noticed the trucks back!
I was waiting to see if a new Duramax was going to be parked in your driveway (or half the the street as it seems) hah!
Brokeboatin221
Well from the pics looks to be in his driveway unlike your Chebby…….
Brokeboatin221
I passed a douchemax this morning that was smoking like your stalking Christmas morning. Laughed as I rolled 290k with my rust prohibiting chassis luber 😂
Brokeboatin221
FYI Duracrap aka 60% Isuzu isn’t American…….. Isuzu is from Japan……. 👍
Gelcoater
Don’t keep us waiting, what was the issue?
Failed injector. I had all 6 done.
Just took some time.
Considered the Banks 6gun deal bit would have been about another grand and the bill was painful enough as it was.
sintax
Don’t have to tell me man, shits out of control.
Went down to buy a length of 3/8 fuel hose from O’rileys, $4.80 a ft!
I could have sworn it was close to $1.20 last time I needed some.
Gelcoater
This truck had an injector failure about 130k miles ago, and never tripped a check engine light.
It cost Moss Dodge and Cummins a long block on their dime.
So, we don’t fuck around with possible fuel related issues round here😉
sintax
Yup, diesel and fuel is no joke
Brokeboatin221
That’s my worst nightmare with mine it can be catastrophic. I think I will be doing mine shortly just to know it doesn’t take out my motor. Did you go stock Bosch or ? I know diesel injection out of fontana formerly colton does great stuff.
