WTB 85841 Atwood Master Cylinder
Dansblown73Nordic
I have an Ellis trailer that has this master cylinder. I guess It is no longer made. Anyone have a new one?
530RL
When Atwood was bought out they quit making the 85841's and the 85376 which was the previous part number.
Depending upon if yours is bolted on or welded on, you are better off just either unbolting the actuator and replacing it or cutting it off and welding on a newer version from Demco or several other manufacturers.
It will work better and you can get manual or electric lock out for backing. If you have to cut it off and weld one on, you can even take the opportunity to add a swivel away tongue to save knees and shins in the garage.
I don't know of anyone with parts as I have the same problem and have looked. :(
Dansblown73Nordic
I think I found one on Etrailer.com . It bolts on. I really don't want to cut this trailer. Thank you for the info. I wanted to add disk brakes but I guess this master cylinder doesn't have enough capacity.
evantwheeler
I bought the same one from Etrailer. No issues installing or bleeding. Bolted right up.
Shrub Lurker
I have access to these dinosaur parts. Limited but available (I know who bought remaining inventory).
PM me, I will only share this benefit to other inmates
SixD9R
Also no help with the original question but wanted to say that you have a beautiful boat.
Rick Cummings
New Member
I am in need of one too! Any help would be appreciated! Would rather not cut my trailer if I do not have to.
mark8251
Where can i find that atwood master cylinder. i have looked every where
guest hs
I believe that’s the Howard that has the sharp nose not the round nose
My220xl#1
New Member
My name’s Gary Teegarden from Round Rock Tx. How much do you want for it ?
Taboma
I know there's more Cole boat owners on here --- so this thread reminds me of the brake work my 1995 Ultimate trailer Jim used for my '95 Superhawk and I reused for my '98 Nighthawk is in need of.
I'm not in Havasu where my boat is, anybody know if those vintage Ultimate Trailers used those same or similar Atwood Actuators ?
My220xl#1
New Member
Not the boat I need an Atwood 85746 drum brake actuator!
