beerrun
- May 25, 2010
- 4,648
- 8,897
Anyone have this system?
please see the predatory homeowners insurance companies thread lolI do but if the fire gets that close, I want my place to burn down.
Have a friend that owns a house in Ventura and when the Thomas fire happened a few years ago, all the houses in her neighborhood caught on fire except for hers and her next door neighbors who is a firefighter. He saved both of their houses. She wasn't too happy about it though because the house was uninhabitable for six months due to all the smoke and water damage. They had to get all the furniture replaced along with a lot of the drywall etc.. She would have rather it burned down to the ground.
Unless you've lost all your memories stored in your house before and you were fine with, I don't think you want that.I do but if the fire gets that close, I want my place to burn down.
This has been my thoughts too but this system can turn its self on the other way we have to be home to turn it onWe are in one of the worst wildfire areas in San Diego County. I have placed sprinklers on our roof in the past when we have been in evacuation mode.
Pretty sure nothing’s gonna burn around my house.
View attachment 1263227 View attachment 1263228 View attachment 1263229
Right I have heard that they turn off the water but they can't turn off the water to my house unless they turn off everyone then they would not have waterDo fire sprinklers work when the FD is sucking all the water out of the nearest fire plug? Or is a fire plug on a separate line? (legit question, not sarcasm)
Once crews start laying hose, I'd expect a noticeable pressure drop. Also for giggles, go out during a stiff Santa Ana and take your best nozzle on a 1" hose, set for a tight strong stream and see how it performs against the wind. You might get a bit wetDo fire sprinklers work when the FD is sucking all the water out of the nearest fire plug? Or is a fire plug on a separate line? (legit question, not sarcasm)
Where do you live can I askWe are in one of the worst wildfire areas in San Diego County. I have placed sprinklers on our roof in the past when we have been in evacuation mode.
Commercial fire sprinklers come off the same fire hydrant and are figured in the calcs for the fire flow. Residential fire sprinklers come off the domestic line. Commercial is to save livess and property. Residential is only for saving lives.Do fire sprinklers work when the FD is sucking all the water out of the nearest fire plug? Or is a fire plug on a separate line? (legit question, not sarcasm)
Yep I remember that fire. Neighbors house burnt down and we are down by Smart and Final and not in the hills.Unless you've lost all your memories stored in your house before and you were fine with, I don't think you want that.
I got into my parents neighborhood by offroading in a buddy's jeep for the Freeway Complex Fire in Yorba Linda in 2008. It was just my dad, my neighbor with a water truck, and me. The rest of the whole hillside, hundreds of houses, evacuated. I've never seen so many grown ass men cry when they saw their houses burnt to the ground days later when they were allowed back up there. People had some major PTSD afterwards and regretted not staying to save their house and others.
In addition, most people were underinsured and had to sue their carriers to get a new build fully covered. It was wild.
My parents had $100k in damage just for getting the smoke smell out of everything. No water damage.
It was so bad the night of the fires that we were smoking cigars in the house and it didn't change the air quality in the house.
Yup, now that works !! So long as you've got a "If all else fails, run" way out of there. If I recall, you may not.This what I have and about 300’ of hose. It has 3 outlets one main and 2 other smaller outlets to run to a big sprinkler system or just more hoses. My pool is my water source. Surprisingly it doesn’t use a ton of water but rather super pressurizes it…you have to lean into the hose when its on full. It came on a cart will all the accessories.
VERSAX® Multipurpose Pump
The VERSAX® is a versatile, rugged and economical twin-impeller self-priming pump powered by a Honda or a Briggs & Stratton Vanguard . It provides superior water-transfer performance as well as the ability to combat fire from greater distances and points of elevation. The VERSAX® is a...www.waterax.com
Gopher Canyon area in Vista. Our property is next to a 330 acre farm so it gives us a little buffer but we have brush that comes down right behind our house.Where do you live can I ask
Thats what I do. Turn it on and let it soak the house down.How many of you have tried to stop a good size wildland fire with a piss hose????? Damn near impossible. the best a roof sprinkle can do is soak the area way BEFORE the fire gets there.
That's fine for a commercial area, but in our rural environment, there's one 12" feeding homes and hydrants that are close to 700' apart.Commercial fire sprinklers come off the same fire hydrant and are figured in the calcs for the fire flow. Residential fire sprinklers come off the domestic line. Commercial is to save livess and property. Residential is only for saving lives.
After about four so far his year in your Gopherville - hood, how's about putting away the matches man.Gopher Canyon area in Vista. Our property is next to a 330 acre farm so it gives us a little buffer but we have brush that comes down right behind our house.
Yep. 45psi won’t help without a booster pump once you do the calcs and figure in the fire sprinkler starting pressure.That's fine for a commercial area, but in our rural environment, there's one 12" feeding homes and hydrants that are close to 700' apart.
All of that comes off the same large storage tank up behind us on the hill and on a great day we see 45psi. Homes up the hill a tad more are down around 36psi.
The homes built post '07 fire like ours, all are interior sprinklered, and also have pressure booster pumps on the sprinkler side, some on both.
Yeah, we get a lot of fires that popup in the area. We are always on the lookout for smoke.After about four so far his year in your Gopherville - hood, how's about putting away the matches man.
I'd pump out of Hodges, but it's damn near empty cuz all the big bucks Richie Riches below us at RSF are scared of that wittle 100 years old damn busting and screwing up their golf course.
The one redeeming factor after ours burned --- was, the new one was good to good for another 5-7 years while Ma nature worked hard to restore the Chaparral. Fire ? Who gives a shit, there's nothing left to burn around here. ---- Now it's all back.Its more for a spot fire like a lightning strike. If it was a wall coming hard id exit. i wouldn't want to live here if the land was reduced to ashes.
Anybody reporting the causes ? Vehicle accidents or bean cookers in the brush ? I recall back in the early 80's when we lived in Rancho Penasquitos and we were surrounded by tomato fields. I'd drive up Black Mountain to fly my RV glider and I could see the smoke down in coming up through the oak trees down in Carmel Valley from the Mexican farm workers who'd made a make shift village down there.Yeah, we get a lot of fires that popup in the area. We are always on the lookout for smoke.
I don't think we have anyone living in the brush anymore. We had illegal camps (field workers) years ago but they are gone now. I have a feeling it's the amount of traffic on Gopher Canyon these days. The fires always seem to start next to the road and spread from there. Could be cigarettes or catalytic convertors.Anybody reporting the causes ? Vehicle accidents or bean cookers in the brush ? I recall back in the early 80's when we lived in Rancho Penasquitos and we were surrounded by tomato fields. I'd drive up Black Mountain to fly my RV glider and I could see the smoke down in coming up through the oak trees down in Carmel Valley from the Mexican farm workers who'd made a make shift village down there.
Now it's the homeless in the river valleys setting them on fire.
This (bold section)^^^^ or a window breaks, etc. People underestimate the amount of embers that blow around during a legit fire. Palm trees are a disaster and should be banned from certain areas of CA because of their ember cast IMO. Wood mulch can also cause big problems. The nice homes that burned during the Thomas fire were helped due to all the wood mulch on the properties that turned into massive piles of burning embers that were being blown around.Before you spend money on that system, spend the money to upgrade all your roof vents to O'Hagen, then box all your eves, preferably with stucco.
Having lost a home in '07, I've watched a lot of live video and watched as home after home caught fire before any adjacent landscaping did.
You'd see smoke start pouring out of the attic, game over. In those same cases, it was the home burning that then caught the landscaping on fire.
You've got to keep the blowing embers out of your attic.
The other problem with roof sprinklers is --- they will be useless on the prevailing with side of the house, which is the side the fire and embers will be approaching from. The wind will blow that spray, especially that small jet, back up and over itself, it won't shoot out 5' against a stiff breeze, which is when our homes are in most danger.
If anything I'd see it as more of a "Why not, I've done everything else I can" approach.
One of my neighbors who lost their home sets up a large gas powered pump, feeding a huge rainbird that will easily shoot 70' or more with a lot of water. He doesn't start it, he leaves it ready to go, with the suction hose in this swimming pool. He's hoping when the fire crew shows up they'll fire it up.
200 psi. Hope you have PRVs for the house. Most high rises / warehouses set their fire pumps at 175 psi max.We have almost 200 psi of water pressure out here. My neighbor has a 2" line with a firehose and nozzle. He can reach out pretty far with that pressure.
I have a valve at our meter and two on the outside of our house where the water comes in. I finally put the one on the meter because it was blowing up our irrigation system. Crazy pressure.200 psi. Hope you have PRVs for the house. Most high rises / warehouses set their fire pumps at 175 psi max.
That was a crazy time. We got to our friends house right as the fire dropped over the ridge and raced down towards their house. We helped them get their 5th wheel and a few essentials out of the house. He got the family out and I stayed behind and got hoses and sprinklers going. The neighbor right next door had no idea there was a fire. I was pounding on the front door to get them out. I ended up dragging hose with the fire department to knock down the hillside before it got to the houses in that cul de sac. We had other friends that weren't so lucky and lost everything.Unless you've lost all your memories stored in your house before and you were fine with, I don't think you want that.
You're kind of making it sound like there are two water mains, which there usually wouldn't be.Commercial fire sprinklers come off the same fire hydrant and are figured in the calcs for the fire flow. Residential fire sprinklers come off the domestic line. Commercial is to save livess and property. Residential is only for saving lives.
PTSD huh? That term gets thrown around way to easy nowadays.Unless you've lost all your memories stored in your house before and you were fine with, I don't think you want that.
I guess it depends on what side of the property line you’re on. But you’re right in most cases. But I have seen dedicated fire mains. 1 line for the fire main and 1 line for the domestic with DDCs connected to the main in the street for commercial side.You're kind of making it sound like there are two water mains, which there usually wouldn't be.
Yup, wouldn't want to do that, like as one prime example.PTSD huh? That term gets thrown around way to easy nowadays.
Let’s not cheapen that term.
Once in a while, when I'd flush a hydrant or do a fire flow test someone would ask can you drink that water, they were usually surprised it was the same water.I guess it depends on what side of the property line you’re on. But you’re right in most cases. But I have seen dedicated fire mains. 1 line for the fire main and 1 line for the domestic with DDCs connected to the main in the street for commercial side.
Haha. Most cities make you use a chlorine type diffuser when doing flow tests these days.Once in a while, when I'd flush a hydrant or do a fire flow test someone would ask can you drink that water, they were usually surprised it was the same water.
100% correct. I know someone that retired from the Navy that is taking 90% disability from the “PTSD” incurred by tripping and breaking their leg on a carrier. 0 loss of function years later that I can see after plenty of serious workouts together.Yup, wouldn't want to do that, like as one prime example.
The Navy shrinks awarding my useless X-son-in-law a life time 90% disability for PTSD he claims he got from being at sea to long as an electronics chief PO on a damned aircraft carrier.
So considering the Navy's handing out those PTSD disabilities like they are the drugs they provided, that are more than likely responsible.
I certainly think the public fleeing their homes in thick smoke, flying embers and total darkness, then losing every personal belonging they've ever owned, is far more deserving of some title for suffering long term issues than a person who served on a floating city.
Do they get a fat check from the US Tax Payers for a drug problem the Navy has decided sounds better if it's labeled as a PTSD long term disability ? No, Hell no they don't.
Yes it does get thrown around and it's unfortunate the military is using it as a "Disability" scapegoat in many cases for a drug problem they're responsible for.
We were special county district and kind of did what we wanted, but I could see that crap coming. You can drink it, water your lawn, but can't run it in the street, give me a break. I was dechlorinating disinfected lines towards the end of my career, but even that was ridiculous unless you were right next to a stream.Haha. Most cities make you use a chlorine type diffuser when doing flow tests these days.
