Blackmagic94
- Apr 4, 2017
- 5,378
- 7,382
Do I legally need wet exhaust on a jet boat for lake Havasu City
No..not "legal"...re-read what boat cop said.So actually mufflers or baffles and I’m legal. Check
Wet or dry doesn't matter. You need to have an effective muffling device installed, in constant operation, and can't exceed certain noise levels.
I won't go into all the noise (decibel) level stuff, but if there's a muffling device (including those that inject water directly into the exhaust stream at the individual header pipes) installed and working, AND aren't being an asshole, then LE will pretty much leave you alone, for the most part. But if you're blowing pipes just for the sake of blowing pipes and showing off, OR using an exhaust cut-off to bypass the muffler you WILL get a talking to.
so if I have mufflers on the headers installed on the jet boat but no water injection. Legal or not? If it is within the dB threshold.
depending on how you've run it either will work.So I am going to run a wide band hence why I don’t want water anymore
Should I block off the water feed line to the wet exhaust or should I make that hose run all the way to the transom and dump to keep flow up.
block it at the T and run it. If you can't balance the oper. temps like that you can add the 2nd. outlet. Have a contingency plan for it in mind just in case.Would blocking off the line that fed the exhaust cause a flow issue in the block
an-08 feeds and splits to both headers with the t valve that opens at 1800 rpm
an-08 on other side of intake goes straight to bulkhead fitting at transom.
So I’ll ask this again if the headers have welded on mufflers and absolutely no hook ups for any kind of water to flow through the exhaust is a dry exhaust legal with an actual muffler?
I never got checked mine was loud but I also didn’t run around being a dick was on mead one weekend going through the narrows about 50 mph went by a cove as I passed the guy with me saw the cop and he turned on the lights we hit the big basin 4’ rollers hang on once he / she ? hit them off went the lights and turned aroundIt's the law!!! If you get Caught
Turbos are a very effective muffling deviceWill have to wait and see about this set up come summer. Ran it a few times in the fall and no issues.
No offense but why did u put a blower on your boat and now put mufflers on? Kind of seems like your ruining the whole point...
I scrolled thru this thread and maybe I missed it.
But I'll spout my worthless opinions anyway.
If your boat is small and a jet, you really can't run it at Havasu most weekends anyway.
It will straight sink in those shitty ass 5ft waves.
And that's also when the cops are plentiful as well.
If you go during the weekdays the water is nice, the cops ain't out and the noise won't matter at all.
You'll also get better water and zero cops if you launch out of Park Moabi as well.
I have never been hassled by "the man" for mine at either Havasu or Moabi.
You just have to lay low, boat right and avoid certain launch ramps.
I wouldn't worry too much about it the noise.
IMO, I would not dump a bunch of money into the exhaust to change it until you have had a problem with "the fuzz", but I doubt you ever will.
But that's just me.
FT
Because I’m eliminating the wet exhaust. I’m running a completely different set of headers that have no water injection and the reason that the water injection was removed is because you can’t have water flowing over an oxygen sensor. I will be running a wide band oxygen sensor to be able to dial the carburetors and perfectly for the air fuel ratio because it’s 2020 and not 1950 any moreNo offense but why did u put a blower on your boat and now put mufflers on? Kind of seems like your ruining the whole point...
This x1000
I have DRY exhaust CMI headers on my 540 blown bbc , that are jacketed and water exits out tail pipe tip . They sound amazing and loud and have yet to have a problem!
You know I have a 35’ cigarette for real water right
Yes no water in my exhaust it is just to cool the pipes they are jacketsso the water out the pipes is dry? Lol
When I mean dry I mean zero water in the exhaust
Well then we don’t need to discuss the merits of what and when a jet botë is safe to operate.
