VST hose connections
1994 235 Edge
Good morning inmates.
Questions on my old VST system.
Any idea where this open port goes?
Is the vent normally connected to manifold vacuum?
Thanks.
vst-png.1249527
1994 235 Edge
Thanks.
I have some of that tubing. I wanted to verify the VST and mechanical pump sight tubes tee together and connect to the intake near the throttle body.
Thanks again.
Trash
Thanks.
Thanks again.
That is correct as others mentioned.
On a separate note, does anybody know the correct plug size to cap off the VST return port?
What fitting would be needed to convert the return line that goes into the return port to something else and go back to the fuel tank?
