Vortec 7.4 454. Piston
69hondo
Anyone id this piston. Numbers don't really turn anything up on line. Need one replacement piston. This is out of a 2000 Worhorse p30or32 chassis
obnoxious001
Engine building character
Is it a stock bore block, 4.250" ? Something about that casting reminds me of KB Hypereutectic pistons. I guess lots of companies should have one, looks to be a stock type replacement if it's not a factory part. Check the other 7 extremely carefully.
69hondo
Yes, stock bore.
69hondo
If that's the case, it would be one GM installed I suppose. Likely I have some lying around here waiting to go to scrap.
lol, ok
Everything I find online calls it a floating piston but mine is definitely a press pin. Is the diameter for the pin hole in the piston the same as a floating and the pin and obviously the rod are different for the floating?
obnoxious001
lol, ok
Right, the end of the rod gets heated and the pin is pressed in, with a stop to keep it centered in the piston.
