V-drives aren’t only found in boats
welldigger00
My pal 025 asked me to help put together trophy truck this year for the norra 1000, in turn I get a right seat. I will be posting a few pics along the way.
Nope. Matt built it himself. It’s very similar to Robbie fukkin Gordon’s truck
Was going to ask if it was a RG Motorsports chassis, looks very similar yet has some real differences but looks like a well build truck with great x’ing should be a great time.
wsuwrhr
The Masheenest
So you've never seen the episode on Road Kill where they put a v-drive in a wheelie truck?? lol
It broke so many times they ended up using a Trophy Truck V-drive. Everything else broke after that change! :p
Shafts and bearings are very different in the truck drive vs a boat drive. :)
welldigger00
Shafts and bearings are very different in the truck drive vs a boat drive. :)[/it’s a big case casale, but the internals are a little different. Tapered roller bearings, different splines, etc.
Terminal Velocity
I've got two of those drives they're Cast Iron and the bearing caps mid plate all are drilled tapped and fittings installed to run as a dry sump setup.
AzGeo
In the past, we've sold Casale V-drives to a number of "wheel stand show cars", and "off road racing vehicles" too .
Very strong and flexible method to transfer power in a different direction .
Not many V drive trucks racing now a days. Not much benefit to running one really. Modern center point J arm trucks are mid engined anyways. Plus more options for mounting spares, tools, fuel tank, etc and less moving parts.
But hard as hell to work on, and you lose a ton of leg room area in the cockpit. Trying to do anything on the front of the motor on most of these that i've worked on is a nightmare, belts, dampner, external crank trigger, etc, it's completely a shoe horn fit in the front, at least when the motor is in the back it's easier to get to the working end.
The V-drive deal still has positives if executed properly. It also has it's drawbacks as well. Biggest benefit of the V-drive is that you can under-drive the drive shaft and put a rear end gear set that doesn't include a tiny little pinion gear that wears out or breaks super fast, if you've ever seen what a close to 6:1 ratio pinion looks like. Makes the rear end work way better running a higher ratio as there is better gear contact. Lots of guys run under drives after the transmissions now to do just that (back to more moving parts) & it shortening the drive shafts, making steeper and steeper u-joint angles.
Like the old saying goes, no free lunch. :p
Hammer
The team I work for has a mid engine Porter with a V-drive. It just sits in the corner of the shop collecting dust though LOL
Tell them I want to use it for a few hundred miles. [emoji41]
Tommy Gun Images
Media Lackey
Staff member
All you have to do is put it back together lol. Actually they just dropped a motor (V10) back in it and are talking about prepping it to sell it.
welldigger00
Does your porter truck have a big aluminum plate one the side of the frame between the fuel tank and the engine?
welldigger00
Seems like Robbie still is doing well in his, I believe he qualified first for the 1000 last year?
Tommy Gun Images
Media Lackey
Staff member
I'd have to look at it again. I haven't seen it in a while.
I didn't realize he was still running the V-drives. But on the same token, he's also notorious for not finishing a race.
welldigger00
That’s not because it’s a vdrive. That’s because that guy runs harder than anyone else all the time. And sometimes a little too hard.
Essexive G's
I worked at a concrete cutting company and we would use Casalle V drives as a PTO to drive high cycle military surplus generators to run concrete cutting equipment. We would run them into the cab with the generator in the cab with the control box mounted on the back wall between the seats. The interiors would only last about 18 months from the heat that the setup produced.
MOUZER
The Legend
i have a casale z-drive for sale...not a v-drive.....made for tricked out truck race car stuff
