DC-88
- Aug 27, 2012
- 1,915
- 5,311
Due to having intermittent issues with zero crank at full ignition / pounding the pedal to start/ ignition first then hit pedal to start I went down the you tube path real quick. Fwiw Batt- good, grounds- good, ignition switch- good . A bunch of hillbilly vids on just twisting the wires together where the sensor is down at the master ( turbo s it’s in a tight spot) and running it . Is this SOP for most ? I’m starting to get visuals of dealing with it in the field … or should I replace it ? Seems like it would be one less thing to deal with to bi pass it - edit ordered new one and some fluid it sounds like codes get thrown without it wired in
