Rjt01
- Mar 5, 2014
- 384
- 628
Been doing research on why fluid to run on my TH 400 and have had a lot of mixed reviews. What are u guys running and why ??? Thanks
Thanks bro , not worried with temp as my trans oil cooler works bitchin but will give it a tryWe run Swepco hydraulic transmission fluid in the trophy truck, and I run it in my boat as well. It handles heat better than anything else. All last week at the Norra off-road race we were continually seeing 280 temps on the trans, and the oil is still bright red.
Just food for thought but the torque converter is where most of the heat is produced in an automatic transmission. Since there are no torque converters in our boats, they do not see the same temps as a wheeled vehicle. Coolers are nice but essentially overkill in a boat (I run one anyway though). I run Valvoline Max Life Full Synthetic in my TH400. It always comes back out red.Thanks bro , not worried with temp as my trans oil cooler works bitchin but will give it a try
Here are your choices as of 1/14/20Been doing research on why fluid to run on my TH 400 and have had a lot of mixed reviews. What are u guys running and why ??? Thanks
YesWhat’s your best practice of checking fluid levels in the 400? Same as a truck? Idle in neutral?
Yes x2
I dont know if it helps, but when I shift from second to third getting on plane I always lift the throttle for a second.
Second though on 400’s. I had a 400 lock up the bearing in the tail. @BoostPower recommends adding an oil line in and out of the tail so that bearing gets lubed and stays cool. Mine was so hot it almost melted my back seat before it gave up the ghost. Ruined a polished case. That was an expensive day. [emoji1418]
What if you idle at 500 to 2000rpm?
Always John Deere hy-gard!!!John Deere hy-gard like sweepco without the price
