cj222
- May 18, 2010
- 493
- 2,193
Just finished this highly modified and refurbished Competitive trailer. Here are some pictures I'd like to share.
Thank you!!What an Awesome transformation !
Excellent JOB !
Thank you!damn, that looks great
Thank you!Trailer is beautiful!!
Thank you! These old Competitive channel trailers are flimsy for sure. The third axle makes it a little more rigid in the rear but the front bow rest and keel pad are what makes it solid .Trailer looks great, By adding a third axle do you think it's going to help it be more rigid? Being a trailer for a V bottom those tend to be much more rigid anyways.
I have an '05 Competitive under a 22' deck and it kills me to tow it any distance, naturally the nose is not fully supported, and the axles are pretty far back, I thought adding a third and splitting the distance might help, and seeing this looks great.Thank you! These old Competitive channel trailers are flimsy for sure. The third axle makes it a little more rigid in the rear but the front bow rest and keel pad are what makes it solid .
Thank you! You would be much better off adding support bunks under the center keel and /or under the front sponsoons if there is enough room. My 26ft deck boat is on a Competitive C channel trailer and it has both of those supports I mentioned. It is a tandem axle trailer and it is solid , no flex.I have an '05 Competitive under a 22' deck and it kills me to tow it any distance, naturally the nose is not fully supported, and the axles are pretty far back, I thought adding a third and splitting the distance might help, and seeing this looks great.
Doing it for stiffness, not really boat weight. Again, great makeover ! ! !
Thank you!Nice work
Thanks for the advice, I'll take a step back and re-evaluate, the back half is supported pretty well, 22' Placecraft. but trailer has so much flex in the front half, and I'm afraid to pin the nose down to use the boat itself to make the trailer more rigid.Thank you! You would be much better off adding support bunks under the center keel and /or under the front sponsoons if there is enough room. My 26ft deck boat is on a Competitive C channel trailer and it has both of those supports I mentioned. It is a tandem axle trailer and it is solid , no flex.
I hear ya. They flex a lot at the bend just in front of that first crossmember because they are a flat trailer and nothing there to support it from the bunks forward. What I have done and would do in your situation to fix that flex problem is jack up the trailer from underneath the first crossmember that the center beam ties into until the trailer jack just comes off the ground. That takes all the load and stress off the front section of the trailer. From there I would build a support up front for the sponsoons and or the center keel depending on how far forward it comes. Doing that will make a day and night difference on how the boat rides and trailer tows behind your vehicle. It will also help prevent the cracking in the frame at the bend point over time.Thanks for the advice, I'll take a step back and re-evaluate, the back half is supported pretty well, 22' Placecraft. but trailer has so much flex in the front half, and I'm afraid to pin the nose down to use the boat itself to make the trailer more rigid.
I will just say that trailer was never up to what I thought it should be. From day one it was a problem, and conversations when they were in Bellflower never really satisfied my issues. I personally have nothing good to say. I'll leave it at that.
Damn, That is a finesse fix. and helps use the boats own rigidity to help the trailer.I hear ya. They flex a lot at the bend just in front of that first crossmember because they are a flat trailer and nothing there to support it from the bunks forward. What I have done and would do in your situation to fix that flex problem is jack up the trailer from underneath the first crossmember that the center beam ties into until the trailer jack just comes off the ground. That takes all the load and stress off the front section of the trailer. From there I would build a support up front for the sponsoons and or the center keel depending on how far forward it comes. Doing that will make a day and night difference on how the boat rides and trailer tows behind your vehicle. It will also help prevent the cracking in the frame at the bend point over time.
Not sure exactly how your trailer is constructed but if you were to attach a bar a couple of inches below the bunks starting from the rear bunk upright all the way to the front bunk upright tieing in all the middle uprights, and then dive down in the front and tie it into the front section of the A-frame, it will also stiffen the trailer. That is what they do on the bigger tunnel hulls. That creates a truss in the trailer frame and makes a huge difference.Damn, That is a finesse fix. and helps use the boats own rigidity to help the trailer.
My approach was a sledgehammer, either add the third axle
(thinking if I built the axles on a separate carriage and mounted that to the frame it would add rigidity),
or cut the center beam out of the trailer from the tongue back to the axles and install a 3X3 .240 wall Spine making the front section more rigid. leaving the front sponsons unsupported but trying to tie the long sides that flex into the center section.
Thanks for the advice.
I see structurally how that ties all of the bunk uprights creating a box tying the long nose or "V" that is basically an unsupported section. And in my situation that's where all the flex is. From the bend in the frame rails forward.@oldman A triple axle trailer would look killer under that deck boat though
Who you callin' old?
