Toyo vs. BFG tires
BMABITY
Looking for some feedback on popular tire choices today.
https://www.toyotires.com/tire/pattern/open-country-rt-on-off-road-rugged-terrain-tires
http://www.bfgoodrichtires.com/tire-selector/category/truck-tires/all-terrain-t-a-ko2/tire-details
I like the look of both listed above and plan on purchasing in either a 35 or 37 here soon.
Those running either tire, what are your likes vs. dislikes?
I will spend most of the time on road with the occasional snow or desert trip, pavement pounder mostly.
j-bone
I've had 3 sets of 35" BFG A/T tires on my 4X4 Excursion and always had a problem with balancing. They would have problems at anything above 75. Switched to Nitto and they perfect. Plus they are cheaper. I'm never going back to BFG. I've never used Toyo but I've heard nothing but great things about them.
Squirtsfar
I have had both. I prefer the bfg. The toyo's cupped and we're noisy as hell once they wore down. I have 30k on the bfg's and they still ride and drive nice, and no howling. 🖒😎
Reactions: Wmc
2Driver
KO 2's are the new design. I think a lot of people will chime in on their experience with the old design which IMO were great too.
A friend is running the BFG's 35 KO2s ( new design) on his Rubicon and is extremely impressed.
28Eliminator
I had the same scenario on my Excursion with the BFG's, but always assumed it was partially due to the fact my rims were 16.5's, and that rim size was being phased out at the time. The BFG's were the only 35" tires made for 16.5" rim at the time.
On the other hand, My Raptor has 35" BFG's on 17's and they're great. Smooth and quiet. I dunno....:smackhead:headscratch:
Icky
I have the open country MTs been running them for years on all my trucks. But recently saw those RTs and am going to try them next time around. My biggest reason why, those RTs come with a 45k mileage warranty, and the MTs don't have any milage warranty, I'm lucky if I get 30k out of them.
getreal
I've used BFG All Terran Radials for the past 15 years. I always got at least 50k miles.
The last set I only got 34k miles. Did some research, United Technologies Corporation bought Goodrich in 2012.
Apparently they changed the compound.
Cole Trickle
I'm a Toyo guy....
Owned a ton of different styles from the ATII MT and the RT
All great tires with great tread wear
lebel409
I have the Toyos on my F-150. I didn't like the idea of import tires, but the BFGs kept getting bad reveiws.
The toyos are good riding handling...better than stock due to the stiffer sidewalls. 265/70R18 on stock wheels. A little beefier but no need for a lift (rubs a bit at the edges of steering and going over a bump). I've got about 35K on them no complaints...and it looks like I have another 20K to go.
:thumbup:
PlumLoco
Vintage Jawa CZ motorcycles
If you haven't given General AT2's a good long look, you should. American made and a huge sponsor of off road motorsports. Im on my 4th set.
I have 35" x 17" bead locks wheels bfg MUDs on my jeep and they just flat out work great, awesome tire! 05 jeep rubicon. They get ran at 8 -10 psi all the time and take a beating!
I have had the toyo open country AT on my 2500 Chevy 35's on 20" rims they worked great loved em, quiet and ran smooth. I had a ball joint problem and they started to go, fixed the problem and got new tires not sure how many miles I had on em.
Replaced that set with the toyo RT, same size, and they are nice but more noise as they start to wear, think I have 12 to 15,000 miles on em. These seem to be a heavier tire, more off road. I've been doing more highway driving.
Next set I will do the open country AT again.
I have an oil change place that rotates and balances my tires with every oil change, that helps!
SBMech
Fixes Broken Stuff
The KO2's are the new A/T's.
They are excellent, and have none of the balancing issues of the old worn out KO's.
I have sold several sets so far and not one complaint, as a matter of fact the ones who tow with them say they are the best towing tire they have tried.
Toyo's in my experience are decent, but not on the same level as the new KO2's.
shippingguy
2007 Ultra 27 Shadow
I have ran the Toyo Open Country M/T's always and I will get 45-50K out of them. I just put on the R/T's last year right before Memorial Day. They are really nice. I am running them on my 2500 with 10inch lift. 37's on 20's.
Outdrive1
I love the Toyo. BFG's just seem dated to me.
UltraLucky
I have the Toyo Open Country AT II on my 2500 with over 55k with plenty of tread left. Been very happy with the Toyo's.
HavasuHank
"B" team gardener
Loved BFG's for years. Always dug the look.
The last 3 sets I had were garbage. Didn't last long even though they properly inflated and rotated.
dread Pirate
Only off road tire I run is BFG. Never had a tire failure that I didn't deserve.
My Dodge had Toyo's on it when I bought it and had a sidewall let go. Lots of tread left, but not sure on mileage. Put BFG's on it and it was like night and day on the gravel road.
Our boat...
I get about 60000 out of 3713.5 r17 toyo open MTs all highway plenty of towing
The key is proper inflation and frequent rotations
Toyo mt tread is deeper and the compound although softer will last longer just because of tread depth great company with awesome support
Bfg has gone downhill recently from what they once were...
jones performance
i used to run bfg at's on everything, treid toyo at's once and was blown away at how much better they rode. been a toyo fan ever since. currently have toyo at2's on my dodge dually and am pleased with them thus far. wear has been reasonable with my heavy right foot and a tuned up diesel. have 38" toyo mt's on my project k5 blazer.
Meaney77
Have you looked at the Pro Comp AT's? I had 2 set on trucks, always rode descent, good tread wear and didnt seem to be over the top expensive.
crzy2bealive
Check out the cooper STT pros. I just got them and really like them.
ridebig
Huge Toyo fan here. I Ran BFG's for year's and switched to the Toyo because my last set of BFG KO's were terrible. I've had two set's of Toyo AT ll's and just put the 37" RT on my 2016 Dodge 2500. I like them even better then the ATll's.
Enen
I've always been a big BFG fan. Lifting the new truck and running the Toyo 37x12.5x20 RT's this round.
BMABITY
Let's see a pic of the truck...
ridebig
ridebig
Thank's. 37/12.50-20. I went with a Carli suspension and it's the best riding truck I've owned.
ridebig
Yes Method Standard wheel's. The Carli set-up is awesome but not cheap. I got tired of spending good money on lesser kit's only to have problem's somewhere down the line.
craiger88
I will echo a few people's comments about Toyo tires. I am on my 4th set of Open Country Mud Terrains after switching from BFG's. I typically get 50K miles out of a set. I rotate my tires with every oil change...makes a huge difference.
plaster dave
Face down A$$ up
There is no comparison. TOYO all day everyday. I've run all of them next best big tire is nitto.
Riverbound
I was the biggest proponent for BFG I ran them on everything including my Rhino. Then I started having issue after issue (balancing, I'll handling, accelerated wear). Per the recommendation of my lift shop I went with Toyo. It was night and day. The toyos are hands down a better tire of you're going to run larger tires with a heavy truck.
I will say you will be hard pressed to find a better tire than the Toyo open country MT.
SBMech
Fixes Broken Stuff
Try out the new A/T KO2 when you get a chance, it's a redesign of the original KO and they are very good. Quiet and very solid feeling, a large improvement of the original A/T KO with none of the problems. Every customer that has switched loves them.
BMABITY
How long are the MT's lasting you?
Taboma
Since you seem in the know with the A/T KO2s. On my 12' F150 Screw Plat 4x4 Eco-Boost, I'm considering dumping the Pirelli Scorpion ATRs (OEM) and going with the A/T K02 in a 285/55/20 (+1).
Going from a P rated to a Load Range D LT, what pressure do the A/Ts need to be run at to maintain a decent ride ?
I've recently encountered a vibration problem once I get over 75, so hoping it's just a tire or balance issue.
SBMech
Fixes Broken Stuff
I tell my customers to run them around 60 PSI to start, obviously if they tow to air them up accordingly to stiffen them up.
You can safely run them at freeway speeds in the 50's but 50PSI is the lowest I would advise.
If you have a vibration only at 75, 70 is smooth and 80 is smooth, it's definitely a balance issue.
Going to an LT is a much stiffer ride, but it also makes trucks handle much better, I don't get a lot of negative feedback usually when I advise customers to put LT's on, especially if they tow.:thumbsup
Modern suspensions are much better at absorbing pot holes and irregularities than the old I-Beam or Leaf Spring suspensions, so a switch to LT's is almost always a positive thing, just need to play with the pressures a bit to find your personal sweet spot.
69 1/2
Wow! I run D rated Nitos on a Silverado Crew and run them at 28psi. They have 23k miles on them and show very little wear. Why so much air?
SBMech
Fixes Broken Stuff
If they are LT's and not P rated, with an 80 PSI max rating, you don't want to run ANY tire less than 60% of it's max load rated pressure, it makes the tire potentially overheat and puts a lot more stress on the sidewall.
60% of 80 PSI = 56.
Is it a 2500 crew or a 1500? Significant difference in tire load based on the GVW between the 2. Some trucks have great alignment from the factory, some eat them up, yours must be a Wednesday truck :thumbsup
jetboatmatt
I have the Brand New KO'2s on my 2500HD Diesel and they are a great riding tire! I have 7,000 miles on them so far. No complaints time will tell. I'm going to rotate every 7-10,000. Need to get on it!
robby dmax
So can anybody say if they have had the toyo m/t and now the r/t what the difference is between the two? As I am looking to replace my toyo m/t that I have had good luck with:)
236eaglexp
I had Toyo all terrains on my 2500HD, great tire. Then tried Falken wild peaks, and had two blowbouts. Was going to buy another set of Toyos but the tire shop had a set of KO2's in stock so I bought those instead. I wish I'd have just ordered the Toyos and waited. They wore much better, were better riding, and more balanced in my opinion. I don't care for the KO2'S at all.
