Suggestions on Good Quality Engine Oil Extraction Pump for Single Engine Boat
Bucketlist
I am seeking advice on purchasing a good quality Engine oil Extraction Pump Unit. Needs to be easily portable in and out of Boat, self contained, either a 12v or 110v pump ok, 12 to 24 qt. used oil capacity. Would appreciate suggestions on the manufacture name of a quality unit and where to buy (if not easily found doing a web search). Thanks.
Runs2rch
Jabsco.
Bucketlist
Thank you to all who have posted replies, I appreciate the info!
Carbidedream
I have a jabsco works great. I believe this is the pump most professionals use.
Bucketlist
I am currently considering purchasing the Jabsco Porta Quick Oil Changer model # 17800 2000 which is described as having a bronze pump housing and a serviceable rubber nitrile impeller kit. This Jabsco model interests me because of the larger pump motor and it has the fittings and hoses to connect to my Mercrusier ( garden hose threaded fitting at the top of the oil dip stick tube. This fitting will utilize the larger inside diameter of the dip stick tube extracting the oil faster. The negative about this model is the large price tage. Hopefully someone here has this same model to answer my question.
My question is how long does the impeller last before it needs to be changed? Thanks for your help
