Stainless CMI Exhaust…perfect condition.
Clank123
These came with a project that I am doing and will not work as I need to go through the transom with the exhaust.
These big block Chevy exhausts are nearly perfect in every way.
Been told they are worth anywhere from 3-5000.00.
Would appreciate opinions on value as I have not set a price(4k?).
Am willing to trade for Imco style cast manifolds with double walled down tubes.
Let’s talk!
sonicss31
Those are an early design. Not sure if that makes them less desirable but I would start to price at 3K. Good luck.
Ragged Edge
Man in the Box
New, these headers are over $ 3,000.00 per side. Pressure test them to make sure there are no leaks and you should be able to get $ 4,000.00 to $ 5,000.00 for the pair.
Clank123
Been pressure tested. Good to go.
Thanks for the input.
altoun40
Let’s talk!
View attachment 1231247 View attachment 1231248 View attachment 1231249 View attachment 1231250 View attachment 1231251
What engine is this for? And where are you located?
