Deano
2006 30' Magic Deck
Maintained with an open check book by Aaron at Absolute Speed & Marine.
Low hours on rebuilt 525 Mercury Blue engines. Only the best parts used. 625 HP each.
Less than 100 hours
J&E Pistons
J&E Piston Rings Clevite Main Bearings
Clevite Rod Bearings
Cam Bearings
Timing Chain Set
Comp Roller Lifters
Comp Roller Rockers
Comp Valve Springs
Comp Retainers
Comp Valve Locks Spring Shims
Ex Valve 16
Mellings Oil Pump
MLS Head Gaskets
Misc gaskets and seals
Merc Fuel Pump Assy
Kendall 20w50 Racing Oil
HP4 Mercury Racing Oil Filter
Fuel Water Sep Mercury
Merc Inline Fuel Filter
Body Impeller Kit Merc
Merc Racing 85w90 High Performance Gear Lube
Bravo Install Kit Merc(O-Ring Kit)
830749 Drive Seal
NGK Spark Plug
Merc Exhaust Gasket
Coupler Assy
Comp Cam Custom
Whipple PCM Upgrade
Bore and Hone TG Plate
Deck Block Valve Job Surface Heads Hone Rods
Accurate Injector Service
Imco mufflers
Low hours on rebuilt XR Drives. 1.50 ratio w/30P Bravo Props
Full hydraulic steering
Nice JL audio system with 12" woofers, 6.5's, 8.8's. Removable speaker pods
Garmin Plotter/GPS
SeaDeck flooring
Fully automatic bimini top
Extended swim step w/ladder
Electric Bolsters and Windscreens
Onboard Charger
Interior is in great condition
Drives and runs excellent. Super dependable.
Always kept indoors, detailed, and ceramic coated.
$155,000
$155,000
  • 30 Magic.mov
    17 MB
Deano
What's the rough speeds with the motors it has?
Low 90's with the 525's before rebuild. It wasn't repropped and hasn't been ran to top speed.
It gets on plane better and has a lot more midrange torque now with the same pitch (30).
There was a whipple ecm installed during the overhauls that raised the rpm limit, but it's never ran that hard.
wfowahoo
Will be looking at boats during havasui boat show week. Any flexibility in price.
Deano
Lowering the price down to 155,000. Killer deal!
