Sold. 2017 Honda CRF 125F-B
Deckin Around
Sold
Sold
Sold
New Bikes, this is no BS
General information
Model:Honda CRF125F Big Wheel
Year:2017
Category:Enduro / offroad
Price as new:US$ 3299. MSRP depend on country, taxes, accessories, etc.
Rating:
Engine and transmission
Displacement:124.9 ccm (7.62 cubic inches)
Engine type:Single cylinder, four-stroke
Compression:9.5:1
Bore x stroke:52.4 x 57.8 mm (2.1 x 2.3 inches)
Valves per cylinder:2
Fuel system:Carburettor. 240mm piston-valve carburetor
Fuel control:Single Overhead Cams (SOHC)
Ignition:DC-CDI
Cooling system:Air
Gearbox:5-speed
Transmission type,
final drive:
Chain
Driveline:#520 O-ring-sealed chain; 13T/48T
Emission details:Meets current California Air Resources Board (CARB) and EPA off-road emissions standards.
Chassis, suspension, brakes and wheels
Frame type:Diamond, steel
Rake (fork angle):27.3°
Trail:94 mm (3.7 inches)
Front suspension:35mm leading-axle Showa® fork; 9.1 inches travel
Front wheel travel:231 mm (9.1 inches)
Rear suspension:Pro-Link® Showa single-shock; 8.9 inches travel
Rear wheel travel:226 mm (8.9 inches)
Front tyre:70/100-19
Rear tyre:90/100-16
Front brakes:Single disc
Diameter:240 mm (9.4 inches)
Rear brakes:Expanding brake (drum brake)
Diameter:149 mm (5.9 inches)
Physical measures and capacities
Weight incl. oil, gas, etc:108.0 kg (238.1 pounds)
Seat height:833 mm (32.8 inches) If adjustable, lowest setting.
Ground clearance:257 mm (10.1 inches)
Wheelbase:1328 mm (52.3 inches)
Fuel capacity:7.19 litres (1.90 gallons)
Reserve fuel capacity:1.51 litres (0.40 gallons)
Starter:Electric
Electrical:Maintenance-free sealed battery
