Desert Center is photovoltaic, not a mirror and turbine system.What about Desert Center? That one is huge!
Looks like it.
The government subsidies ran out so now they have to run it on their own nickel.Serious question- what is expensive about running this plant? Isn't it self-sufficient for the most part?
I hate to disagree with you but it will be our childern and grandchildern that will be paying fot this and all the otrher f*cking buill shit that all these global warming IDIOTS have brought aboutJust another fine example of a government backed Folly that we will all pay for!![]()
There is another one North up the 95 by Tonopah that Blowbama gave to a contractor in Spain to build. Took all the water rights from the local farmers etc. It was shutdown for awhile because it never worked right execpt killing birds. Came back on in 2021 I think.It's a middle eastern company that built it and owns it. The Obama administration gave them the land and the grants to build it. I could go on and on about what a failure that was.
They also almost didn't build the 3rd tower because they found too many desert tortoises.
When it was designed, solar panels were WAY more expensive than they are now so the cost per KWh from this plant was less than the cost for a similarly sized photovoltaic system. By the time they had it built and operational, photovoltaic costs had come down so far that they could undercut the power from this plant and sell for cheaper. I believe these guys have been running at a loss since almost day 1. Current photovoltaic systems with the same output are something like a third the cost...Serious question- what is expensive about running this plant? Isn't it self-sufficient for the most part?
Look at that ugly piece of shit desecrating the pristine desert. The motherfuckers in government that think the desert is there so solar arrays can be built need to be tied up in the concentration point of those towers and incinerated.Looks like it.
11 years after a celebrated opening, massive solar plant faces a bleak future in the Mojave Desert
What was once the largest solar power plant of its type in the world appears headed for closure just 11 years after openingabcnews.go.com
My guess would be, paying people to keep all those mirrors clean.Serious question- what is expensive about running this plant? Isn't it self-sufficient for the most part?
I hate to disagree with you but it will be our childern and grandchildern that will be paying fot this and all the otrher f*cking buill shit that all these global warming IDIOTS have brought about![]()
This is correct. My son worked there when it first went on line. Only on the hottest days would the solution get hot enough to not need natural gas to be operational. The rays from the mirrors would vaporize birds and the company tried to keep that from the public. The system didn’t work in Germany either but the company received government grants and funds to build this facility in the United States.If I remember correctly, it has to use vast amounts of natural gas (more energy than the plant produces) to keep the saline slurry solution heated enough to produce steam for the generators to run efficiently.
If Trump hadn't been elected, the next government run taxpayer theft was going to be hydrogen power for transportation.If they were subsidized by the government, than they're planned failures anyway. Probably, a bunch of greenies walked away with a shit load of tax payer money..
All you can eat till they close!Damn.. This means no more Popeyes Chicken Strips?
Yeah, expensive to run.
The similar type between the 10 and 40 in Barstow shut down some time ago if I recall right.
My wife used to work for the Israeli company that built some of those off the 40. Bush rescinded the solar tax credit. I saw it on the news one night and I told the wife “ shit were screwed”.Yeah, expensive to run.
Big one on I-10 just west of Blythe.
Good question - there a number of things at play.
It was horrifically expensive.
it never did hit its performance target
It takes an unbelievable amount of natural gas every day to keep the molten salt hot enough to continue producing power - way more than a standard gas turbine so when the sun isnt shining its going backwards.
Its fragile, the mirror motors go down a lot reducing efficiency.
It takes a ton pf people to keep running and fixing it.
Troughs are way simpler and work better.
A panel farm has zero moving parts and requires only cleaning.
Panel farms have lots of moving parts, every panel is on a tilting mechanism to track the sun.
They also require a fuckload of cleaning to keep efficiency up.
