- Nov 9, 2010
- 18,391
- 23,719
To keep it simple lol.
Panel A (main panel) 200amp with a permitted 12kw solar array tied in. Solar has controller>panel>disco prior to hitting 60amp breaker in main.
Assume everything below is a separate building with 100ft run in between.
Panel B (fed from A) 100amp with 6-7 circuits
Panel C (fed from B) 100 amp 28ish circuits
Panel D (fed from C) 100 amp 12ish circuits.
Not that it matters but all of this runs and nothing is over loaded lol.
Now client wants to add 3.2kw of solar to Panel C. Now I’m always wanting to learn but my red flags immediately go up. Apparently a local solar supply house says good to go. They advised to wire a separate controller, panel and disconnect and then to feed panel C.
From strictly a safety standpoint Panel Bs feeder from A needs its own disconnect at the main. Also now Panel C’s feeders are also potentially live solar circuits to Panel B and D.
I say no go but I only rough in for solar.
I’ll add I have someone much smarter and with a lot more employees meeting me in the morning to check it out.
