D19
- Aug 13, 2018
- 2,441
- 4,873
Has anyone here used these instead of tearing the roof off?
Sooo asthetically pleasing. HahaThat's some quality electrical work.
I looked into and read the site as it was interesting. You cut all the way down to the wall plate and it sits on that. So its not weight on the decking etc.Eeesh, is it just lagged to the deck or do they find a joist? Seems like a lot to ask for for 1 joist or 4 lags in the deck, maybe if you don’t cover the top and leave it open to air flow. Either way it looks funky and bolted on IMO.
I prefer to just drop 2 posts at the roof line
That’s part of the problem with these posts. Doesn’t give you anywhere to disguise the EMT. I’ll opt for going underground to the outside posts and run it there but many homeowners don’t wanna pay for that. I think if I did residential electrical I wouldn’t give them the option. This is the right way, this is the way someone else will do it, not me.That's some quality electrical work.
Having been in solar a long time and having seen a lot of mounting methods I would worry about water intrusion after a few years. The boot is exposed to UV, the elements etc. If it leaks it’s going to be directly into the wall not a ceiling where it’s easily detectable. IDK if I would do it personally, but it’s nhave the same denim an interesting mounting method.
A lot of these kind of structures in HI are made of fiberglass or other composites lightening the load quite a bit. There is a company on Oahu that makes them for a lot of hotel/government/com projects as well as residential. It wouldn't surprise me at all if that was one of their deals.I have the same situation trying to tie shade to a roof line.
When we were in Kauai of all things the Hertz rental building had a large shade structure coming right off the roof line. They had custom brackets built that tied to the end of every joist end that protruded beyond the facia to connect to a lateral of the shade structure. I may have saved a pic of the bracket. I was pretty cool and clean
Wow, not stamped steel like most Simpson stuff. Appears to be all cut/welded SS plate and would cost you a small fortune to purchase I'm sure.I found the pic of the bracket. Im not sure how much load they could take if you tied into 10 of them?
My issue is Id like to tie to the roof but cant and don't have a place for 2 posts for the house side for a gazebo
I've been looking at these mounts as well...just worried about potential leaks. I live in SoCal though so might not be a problem...just wonder how this would work on a composite or clay roof?
