Desert Whaler
- Oct 28, 2020
- 4,909
- 18,170
I removed 2 of the old pressure treated 4"x4" posts and all the concrete that I had set probably 20+ years ago.
The bottom 18" were rotted out to mush and soaked with water.
I had set them in sono-tubes and used high strength Quick-Crete about 24" deep with rock base at the bottom.
The problem is that it's located right on the property line, at the entrance to a backyard RV access and between 2 concrete slabs.
There's about a 12" space that runs the length of the RV access and separates the 2 slabs.
It used to be all dirt and when it would rain, it would flood and make a big messy river of mud when it overflowed.
A year ago I dug down about 10 inches and filled/ packed it with road base, then I filled the top 4 inches with decorative rock that averages a bit bigger than a golf ball.
So now there's no mud-flow . . but the water runs downhill in that direction where the posts are.
The last ones lasted 20+ years so 'ok' I guess, and I don't wanna remove the rock and pour concrete.
I'm curious if anyone has suggestions on how I can set new posts and protect them the best I can from water intrusions.
I've got a roll of Bituthene I was considering wrapping the posts in, that stuff has always worked well for me.
I was considering setting the posts inside a large PVC pipe, but the water will just come up from underneath.
I guess I could use a steel post as well.
Any advice would be appreciated.
I'll Shoot a pic. and add it to this post.
Thanks in advance.
The area where the posts will be is under the plywood.
Thanks in advance.
