Big B Hova
HOSS
- Nov 7, 2014
- 5,716
- 12,408
So I went to drain the fresh water tank to sanitize it and top it off with fresh water. When I touched the plastic drain it crumbled into pieces. I run to home Depot and buy a hose bib with the same thread. Go to thread it in and the fitting split in half. So I epoxy the shit out of the fitting, let it cure, fill it and the fucker is now leaking at the epoxy seam to the tank. I was just trying to do a quick fix for desert trip this weekend.
How hard is it.to replace the actual fiting on the tank? I found the pieces online. Just curious how I can remove the old epoxyed fittings. I need to replace the other 2 fittings as well as they are also cracked.
