Road clisures
cmbailey1077
New Member
Hi, I don’t know if I’m in the right area. I’m traveling home from Lake Havasu today. I usually take the 95 to the 62 to the 177 and get on the 10 westbound last time. I had to go take the 62 to the 177 and then go to Eagle Mountain to get on the 10 westbound. Are those on ramps open going westbound coming from the 95 from Parker or do I need to go all the way around 1000 Palms and Joshua tree.
OCMerrill
All in...
Nothing has changed in nearly a year now. Follow the detour signs and you will be fine.
177 to Desert Center and make a right (west) on Ragsdale Road to Eagle Mountain on-ramps in either direction.
I believe the bridges on Ragsdale Rd. are weight restricted so you will likely see less big rigs. Likely is the key word.
HNL2LHC
As noted on ramp is closed you just have to use the road that runs next to the 10. Here is a map if you google Desert Center you can see the closure .
HNL2LHC
This detour is not even an inconvenience.
You are so right!!! All the talk of being closed and the first time going that route it was not a big thing. It was just like someone had said something crazy like…..Parker was closed. 🤪 🤪
Andy B.
What about going west on 10 and existing at desert center? A month and half ago it was closed and I had to go all the way to the 95.
They use to have detour 10 miles up going east and you could turn around and exit at desert center going west but the whole exit was completely closed in both directions.
UltraLucky
West bound 10 offramp at desert center was open yesterday. On ramp may have been open aswell.
Angler
Tritoon Racing
Wait, Parker is closed till November.... 🤣
Headed out there next week or two...
DarkHorseRacing
Eastbound 10 to Desert Center is now open. You don't have to go Eagle Mountain. There is a sign right before EM telling you DC off-ramp is open.
Going under the freeway from the off-ramp you can see the work they did. It appears to be done.
Andy B.
Yep I went thru yesterday around 4:00 pm all ramps open!!
