RiverDave’s Garage Sale!
Sold for a great deal! Someone should have made an offer!
now off being mechanically restores.. when it’s perfect again I’m going to send to a hot rod shop
off the market
The Holy Grail is up for sale!
1998 Hallett 270T with Merc Racing 377 Scorpions with big tube headers! (The guy that built it worked at Merc racing and from What the original owner told me these scorpions are a little more tuned up then most) Compression is perfect on the motors, but it will need valve guides in a couple seasons (smokes on start up). Real Merc K planes (not those cheesy Bennett trim tabs), real Latham full hydraulic steering ($$$), real Latham offshore controls ($$$), When this boat was built they spent ALL THE MONEY. On board fuel transfer station to transfer fuel out of the boat and into jet skis. Foot shower in front (original from hallett)
I have cleaned this boat up a lot since I first bought it..
Had the cabinets redone, butcher block tops, bar (bottle holders) all remade and fit the more popular brands of alcohol, butcher block cooler Lid / serving tray. Cooler pulled out and actually insulated (it wasn’t from the factory).
White led lighting throughout / Red LED lighting throughout. Custom chair rail in the bow to hide the lighting (indirect). TV / DVD player / 110 volt inverter.
MASSIVE STEREO - 5 amps (one hidden) 4 12’s under the back seat, 4 8’s, 6 6.5’s... all top of the line. 4 giant full river batteries means you can play it all day and night if you want all weekend long. Stereo hits hard enough it will actually blur your vision. Stereo alone is just shy of 18,000.00
Noco genius 4 bank on board charger.
69,900 OR BEST OFFER.
Title in Hand ready to roll. Any questions call 949-678-8369
25 pitch Trophy 4 blade stainless prop.
275.00
1 5 blade 21 pitch Signature (hill marine) Stainless prop! 350.00
1 21 pitch Mirage plus stainless 3 blade. Slight feathering on the leading edge (minor)
225.00
Stock wheels and tires off a 2020 Can Am Turbo RR.. about ten miles on them
450.00
BajaT
Garage sales usually have better turnout during cooler months, not the hottest week of the year!! :)
Wasn’t Me
I want to know what the new boat looks like???
HBCraig
Has anyone ever Whipple charged the 377 Scorpion motors?
floatn turd
Hello,
I'd like to put an offer in on;
"The sexy plastic lady leg glass seen below in picture #2?
Please advise if the oversized accompanying sipping straw is still available a well?
And........... please don't judge me!!
FT
DrunkenSailor
Bolting the whipple on would make these 500 horse motors. Thats a ton of get up and go for a 270. Please do a build thread if you go down this road.
Whipple 377 Black Scorpion (02-08) (ECM 555)
485-5009 + Option(s)
  • Features:
  • Up to 50% horsepower increase from idle to redline
  • Reprogrammed ECM 555 for complete engine management including fuel, spark, knock control and engine guardian
  • Instant boost, no lag as does centrifugals
  • Instant throttle response for excellent acceleration and drive-ability
  • Flat torque curve across wide RPM range
  • Billet high flow throttle body
  • Supplied high flow fuel injectors
  • Whipple low profile intercooler for incredibly low inlet air temps
  • More horsepower and torque than a 496 Magnum HO
  • 10-rib serpentine belt system
  • Completely self contained oiling system
  • Most efficient supercharger on the market
  • Easy to install without internal engine modifications
  • Incredible results for boats that suffer from high elevation applications
  • Supercharger has lowest noise level in industry
  • Powder coated and anodized black for excellent corrision resistance, polished finish or a custom color is optional
  • Complete system with larger fuel injectors, 2 bar map sensor and all the proper hardware for an easy installation
Do you want big block power but don't want to have all that excess weight and low fuel economy? Whipple can give your 350 Magnum and 350 Black Scorpion a huge jump in power that will simply outperform nearly all big blocks. Skeptics say, “what about torque?” That’s simple, the Whipple twin-screw type supercharger will give your small block more torque than typical 502ci engines, because of it’s unique design, the Whipple Charger can generate full boost at any rpm, just the touch of the throttle and you have instant power. Other skeptics say, “Well you can’t have low end torque and top-end horsepower!” Yet again, the facts differ, most don’t know that the screw compressor is one of the most efficient superchargers ever built. What does this mean? Massive torque levels that are simply unmatchable while simultaneously producing mind-boggling horsepower. No other supercharger in the world can offer this type of torque down low with the incredible top end horsepower. Who wants to wait for the power when you can have it instantly!
  • Features:
That will probably still work, but it is for the black scorpion. As I understand it, the blue scorpion is a bit different engine, but all the important stuff to get the supercharger on is likely very similar or identical. They are all 377 small block chevys with Vortec heads. The scorpions had a different intake than the standard 6.2. The black scorpion had the same cast exhaust as the standard 6.2. and the extra 20 HP was likely just from the intake, I do not know if it had a different cam. The blue scorpions had headers as well and had 50 extra HP over the standard 6.2. Again, I don't know if there was a different cam in the blue ones or not.
Qty 4 22 inch weld wheels f150 / navigator bolt pattern. They are worth about 100 a whack down at the recycler from what I have been told. Some of the spokes have hairline cracks. I was going to turn them into pub tables and a coffe table with a glass lid. Never got around to it.
Free!!
Rock tamer thing for back of truck.. sold to @02HoWaRd26 pick up this weekend
SOLD
BingerFang
Who woulda know the owner of the coolest boating forum (only because Grads is gone) owned a 2WD truck.... C’mon Dave!!
eand28
200.00 or make offer View attachment 903894
Got pics of the hairline cracks?
SOLD
2 complete aqua scooters and 1 parts one
SOLD!
Halo style drive shower - 25 bucks
rrrr
Spot price for aluminum wheels is at 34¢ a pound right now. You missed a decimal point. 😁
Spot price for aluminum wheels is at 34¢ a pound right now. 😁
I dunno from what I’ve been told they are a 100 a wheel at the recycler.. I’ll cut the price in 1/2 though. 100 bucks
TrollerDave
