Tamalewagon
Little Buddy
- Sep 24, 2007
- 9,652
- 3,611
After deep cleaning the boat, I need a compound or polish to make it all purdy. Suggestions?
3M Finesse It.
I use this also. It works good, and is easy to work with.This is a great all in one.
Some may laugh at it because of the corny commercials they used to play on tv, but it holds shine longer than the carnuba waxes of that time period.Nu Finish isn't too bad, used it more than anything else since the boat was new in 08.
I haven't used ceramic or nano, I have used Colonite and 3-M with no real noticeable difference.Some may laugh at it because of the corny commercials they used to play on tv, but it holds shine longer than the carnuba waxes of that time period.
Because it’s a polymer not a wax produced by natural sources.
Would be interesting to see a real world comparison between it and some of these ceramic or nano products out today.
Edit....
Uncle T should be by shortly to reprimand me for not knowing ceramic and nano waxes are indeed...polymers.
Big fan of the Shine Supply products. My son has done a lot of research on different chemical compounds used in most popular brand products and keeps going back to Shine Supply. It works better and lasts.This depends on where the gel is. How aggressive you need to be. Wake up by shine supply with an orange foam pad is great for light cut and high polish. It is si02 infused. Thats what I'm doing this winter. Then I'll re coat with beadlock marine ceramic coating. It's been 4 years since I did it last.
When I did it last time I needed an aggressive compound. So I went chop top with a microfiber cutting pad. Followed by classic polish. Then I coated with two coats of regular beadlock. Marine wasn't out back then.
I got severely admonished in another thread for recommending the Meguires hybrid ceramic wax and doing it yourself …What you need to do is pay somebody $3,000 to wipe on 3 ounces of ceramic on it. That's what you need to do!
The $3k is not for the ceramic its the hours of labor/polishing to get the surface properly corrected and ready for ceramic. That's if its done properly. All of these off the shelf one step ceramic waxes in a bottle are all BS IMO.What you need to do is pay somebody $3,000 to wipe on 3 ounces of ceramic on it. That's what you need to do!
THIS......Shine Supply makes some amazing products. I have been using them for close to 10 years now. The problem with these threads is one guys idea of a shine is completely different than that of others.Big fan of the Shine Supply products. My son has done a lot of research on different chemical compounds used in most popular brand products and keeps going back to Shine Supply. It works better and lasts.
