X-2 on the Thuren or Carli systemsI have been happy with this Thuren kit on my 2018, tow a hefty 5th wheel made the front end much more plush when hitting gullies and pot holes
Thuren 2014-2024 RAM 2500 Diesel 2" Level, HEMI 3" Level, 13-24 RAM 35
Thuren 2014-2023 RAM 2500, 13-23 RAM 3500 4WD Diesel 2" Level Kit With Fox Shocksstraptperformance.com
Thuren offers a 1",2", and 2.75" for the diesels.Exactly what was said above if you want to go 2.5”
On my Ram I only wanted 1.5” which any cheap leveling puck or block can do.
Good to know, Carli told me the rate was to soft for a shorter level. Mine was a gasser so maybe that was a smaller market that they didn’t care to explore.Thuren offers a 1",2", and 2.75" for the diesels.
Yeah, Carli offers the 2.5 leveling spring and the 3.25 lift kits. I think both brands offer top quality parts so you really can't go wrong with either.Good to know, Carli told me the rate was to soft for a shorter level. Mine was a gasser so maybe that was a smaller market that they didn’t care to explore.
How did the coils settle? Front end still have a rake? My '24 has a 3" rake factory so was looking at 2.75 to get more levelI have been happy with this Thuren kit on my 2018, tow a hefty 5th wheel made the front end much more plush when hitting gullies and pot holes
I'm in the market for my '24 CTD, think I am set on the Thuren 2.75 Coils, track bar front and rear, and Fox reservoirs and IFP rears. Seems to have good reviews
2014-2024 Dodge Ram 2500 Fox 2.0 Remote Reservoir Front Leveling Kit
Enhance your truck's performance with Thuren Fabrication's Leveling Kit: Front Soft Ride Coils, Trackbar, Fox 2.0 Remote Reservoir Shocks with mounts. Choose coil springs lift height wisely. Additional guidance on front coil springs pages. Improve your ride now! #ThurenFabrication #LevelingKit...www.thurenfabrication.com
295/65-20 will measure 35"x 11.5 and fit with no clearance issues on the stock wheel. If you want 12.50's you really want a wheel with a different offset. CJC Offroad has a ton of videos on how to get the best fitment on the Ram.Well not to thread hijack, but I had the Thuren 2.75 kit in my cart for awhile, lol but hit the complete purchase button after this threadNow I gotta figure out tires
X-2 for CJC Offroad..Cole,Cody and the team are top notch and won’t up sell you.I echo everything above. '18, 2.75" Thuren springs, Carli track bar, and just Bilsteins all around since I aint rich lol. On my mega cab it rides perfectly level due to weight of larger cab. Stock coils in rear with Timbrens when I tow 5th wheel. Rides like a dream. 37's and Method -18mm offset wheels but I usually tow with stocks due to the gearing. Whatevery you do, GET THE TRACK BAR. The stock ones are terrible. CJC Offroad in Long Beach is the one stop shop for these trucks.
Nice. Just watch the rubbing on sway bar and control arm when going larger in tires on the stock rims. Like the post above me, CJC has perfected the offset issue and taken the science out of figuring it all out. That's half the reason I stayed w 37's that are still 12.5 wide and not 13.5.
I was actually thinking of a 325-60-20 to get a true 35" tire on there, they are actually 35.5. Watched a youtube video of a guy who did the same kit and that size tire and had very minimal rub with stock wheels. I would like to go 37's but it will be used to tow an RV so want to keep the gearing.295/65-20 will measure 35"x 11.5 and fit with no clearance issues on the stock wheel. If you want 12.50's you really want a wheel with a different offset. CJC Offroad has a ton of videos on how to get the best fitment on the Ram.
Stock: 285/60-20 = 11.22" wide/33.46" tallI was actually thinking of a 325-60-20 to get a true 35" tire on there, they are actually 35.5. Watched a youtube video of a guy who did the same kit and that size tire and had very minimal rub with stock wheels. I would like to go 37's but it will be used to tow an RV so want to keep the gearing.
Most 37's measure 36. Looks way better. Your effective gear ratio won't be a whole lot different vs a true 35.I was actually thinking of a 325-60-20 to get a true 35" tire on there, they are actually 35.5. Watched a youtube video of a guy who did the same kit and that size tire and had very minimal rub with stock wheels. I would like to go 37's but it will be used to tow an RV so want to keep the gearing.
I will probably just do a new wheel and tire setup, I don't care for the pizza cutter look with tall skinny tires.Stock: 285/60-20 = 11.22" wide/33.46" tall
295/60-20 = 11.61" wide/33.9" tall - no rub
295/65-20 = 11.61" wide/35.09"tall - no rub
325/60-20 = 12.79" wide/35.35"tall - rub
We all know 35's aren't usually 35" tall so the metric sizes will be more accurate. You can probably get a 35/11.5-20 that will measure closer to 34.5" tall if you want to keep it closer to the stock 33.4" height, but bigger than the 295/60. The 325 is 12-3/4" wide and will rub the radius arms and sway bar on the stock wheel according to the interwebs.
Yeah, Nitto claims my 37's measure 36.77 but I haven't measured the actual mounted diameter. I just know they rubbed my inner fender so had to do a little clearance work LOL!Most 37's measure 36. Looks way better. Your effective gear ratio won't be a whole lot different vs a true 35.
Nice choice! You will not be disappointed.Thank you for all the great suggestion. Going with the carli back country kit.
Looks good, any rub?
I run that 3 1/4 Carli kit and love it. Rides good and looks good with 37'sThank you for all the great suggestion. Going with the carli back country kit.
That is bad ass congratsPut the Thurem Kit on today, with some Method 18” NV and Toyo AT3 37’s. Night and day ride quality! View attachment 1485611
Did you go 2 or 2 3/4 springs?Put the Thurem Kit on today, with some Method 18” NV and Toyo AT3 37’s. Night and day ride quality! View attachment 1485611
2 3/4 with the Fox reservoirs. Sits about 1/2” lower in the frontDid you go 2 or 2 3/4 springs?
I just got all the goodies together for AlfaOBD to work on my truck. You can set the TPMS threshold to allow you to run less tire pressure. Also works to change a ton of other things in the BCM.Put the Thuren Kit on today, with some Method 18” NV and Toyo AT3 37’s. Night and day ride quality! View attachment 1485611
I ordered the bypass cable yesterday from KAODTech, hopefully get it calibrated by the weekend. I used the AlphaOBD on my dually, great tool for sureI just got all the goodies together for AlfaOBD to work on my truck. You can set the TPMS threshold to allow you to run less tire pressure. Also works to change a ton of other things in the BCM.
Links to solved DIY Sales code mods and common AlfaOBD settings
Here's a roll-up thread for posting links to any successful DIY Sales code mod and AlfaOBD settings required (or not) and common AlfaOBD settings only mods. This is NOT a How-To or Q&A for AlfaOBD or discussion thread. Links and settings only please. TL;DR If you're not here to contribute, you...hdrams.com
I have the fox TS, it is not strong enough for 35s+, spring for the ATS or King unit. I get some feedback when hitting bumps at high speeds- like sweeping curves on a highway.I haven't ordered one yet either... I'm thinking about going with the Fox TS unit.
I put the King SS on yesterday, WAY better than stock. Don't get any feedback on bumps at speedI haven't ordered one yet either... I'm thinking about going with the Fox TS unit.
