Cdog
- Apr 8, 2008
- 8,389
- 17,640
Updated!!!
So I scored a Procharger from a rdp member this week. Killer deal! The Procharger system is set up for a mpi 502. Ive already tracked down a serpentine belt system for the engine assessory drive.
If I can get 600 + ish hp out of this set up I’m pretty happy. Should make a 21 ft Howard RC I/o haul ass.
I picked up a Arizona speed & Marine/Pfaff 600 hp intake, similar to the efi 500/525 intakes but better. These are built to support more naturally aspirated HP. Plans are to modify the intercooler to mate up to the ASM single blade 1100 cfm throttle body. Has anyone done this set up? I bought this intake off a board member who said it supported almost 700 hp on a 540ci.
I need to start looking at hydraulic roller cams as well. Any recommendations or grinds for a blown 454? Looking for a noticeable idle & a power curve that works with the intake. Engine has roller rockers already. I’ll port match & do arp head studs when I swap cams.
I received a harness & mega squirt ecu with the intake but have also been looking at the Holley HP ecu & harness.
For a fuel system I’ll probably go with a aeromotive efi pump. If anyone has a used set up they want to get rid of please pm me.
Pics of intake, valve train & current engine configuration.
