Cdog
- Apr 8, 2008
- 8,558
- 18,311
Anyone know what size this is so i can order a replacement? It’s the small one. The hose failed at the crimp and is seeping fluid.
So just an update on this.
Seems there's no easy source of a fitting that goes from the new rams metric threads to the standard inverted flare to retain the original power steering lines. The closest I got was a fitting similar to the one shown in the original post (Weatherhead 1446 LS conversion fitting) that has the correct metric/flare threads but is about .125" too short. I could have just spot faced the new ram letting the fitting sit in deep enough but this wouldn't have helped me with the low pressure return side.
After a bunch of google research I finally decided to just make some fittings. I ended up making them with the metric "male" o-ring threads and 1/8 NPT on the female side since I didn't have a tool to get in and make the inverted flare profile. This way I just bought an 1/8" MNPT to inverted flare adapter fitting for both pressure and return sides. I wouldn't like to have a single fitting but oh well...gotta work with what ya got!!
Also, since the info isn't really out there on thread sizes I figured I'd add them here in case anybody searches about the same conversion in the future.
High pressure fitting:
Old ram 1/4" inverted flare (7/16-24)
New ram 14mm X 1.25 metric o-ring
Low pressure return:
Old ram 3/8" inverted flare (5/8-18)
New ram 16mm X 1.5 metric o-ring
A little time on the SL10 and here's where I got.
Threw them on the Bridgeport and put the hex on, then on the Logan manual for a quick touch up to the hex and all done.
Going to put it all together tomorrow and make sure it's all good!
Here's what I leaned recently, should have the info you need. (Not sure if my link to the post will work but here goes)
Yours are standard size fittings, uses 7/16 and 5/8 wrenches. The newer steering actuator with metric fittings is aluminum and looks different. Yours is based off a c3 corvette steering control valve and actuator.
That looks like the older saginaw valve, not the newer brazil valve
https://www.mercruiserparts.com/55116-hyd-hose
Non Metric
https://www.mercruiserparts.com/90494-hose
Metric
Take the hose off and take it to a hoseman shop they will make you a new hose using your original fittingsAnyone know what size this is so i can order a replacement? It’s the small one. The hose failed at the crimp and is seeping fluid.
