Platinum or regular def?
ka0tyk
Does it make any difference?
RichL
Actually never saw the platinum version before. Just refilled the tank in the Ram about an hour ago with the original Blue.
robby dmax
I just bought some myself trying to get the tank empty to full up with the new stuff
ka0tyk
Im new to this diesel stuff. I was driving home from Palm Springs and got a message that the engine wouldn’t start after 250 miles. That was pretty strange. The little “level” in the info system said we had like 1800 last time I checked when I changed the oil. It took the whole box so it must’ve been lower than what it thought. Now I know to keep it topped off if it ain’t gonna start when it runs out. Dumb emissions...
ka0tyk
What ever meets the spec called out in the owners manual.
It’s a land rover...the DEF you choose will not prevent impending doom.
but I bought the good oil. That gives me at least another year right?
LowRiver2
Article on the why: Still researching the difference .
Less impurities might be better for making UREA IED’s, lol
Taboma
Interesting that the info message states "Incorrect Diesel Exhaust Fluid Detected", rather than a low level. I know my neighbor has had his Jeep Grand Cherokee going into limp mode numerous times stating it had a clogged DPF filter, despite him having driven it at freeway speeds for plenty of miles for a regen. Dealer's done a forced Regen about three times now under warranty, yet claims there's no problem.
Reactions: DWC
ka0tyk
I think it was just really low. I filled it up and no message anymore. Fluid level on the dash says 10k miles till empty.
DRYHEAT
Do any of the gas/fuel stations have DEF at the pump or do you have to buy the little boxes to fill your DEF tanks?
pronstar
President, Dallas Chapter
Lots of stations have it at the pump [emoji106]
DRYHEAT
Some truck stops do... But I buy the standard box DEF without issue. It's annoying to do..but takes like 5 min
I thought they might have it at the truckstop/travel center RV pumps but I just have never paid much attention I’m usually on the other side, I just wondered if your big stations in the big cities had them. Can’t say I’ve ever noticed in Havasu but then again I’ve never really looked all my junk is gas.😊
yz450mm
Some stations definitely have it at the pump, seems to be getting a little more common these days. I also use the blue boxes you can get at Home Depot/lowes,or any auto parts store.
I'm not sure about the other brands, but my GMC gives me plenty of notice that I should throw a box in there. I think it starts at 1k miles of range, then 750, 500, 400, Etc, so it doesn't let it sneak up on you.
Sent from my SM-G988U using Tapatalk
Bowtiepower00
If I need to use “premium” DEF, my shit is getting deleted. Bunch of bullshit. I have read about guys using distilled water without issue depending on year/make/model of truck. I might end up going that route if I have issues. Trying not to delete as I have an extended warranty.
LowRiver2
The early 6.7 Pstokes (11-14) have had DEF sensors go more than other brand sensors listed on some discussion boards.
It appears to come down to the purity of the mix as to deposit build up in the system.
I’ve had 0 issues in nine years with the standard stuff, going to stick with it and save my money for guns.
81Sprint
i went from LBZ to L5P duramax, no def before and i learned real quick to spend a little more to get the box with the filler hose after not having it and spilling that shit. I could definitely go for a "weight loss" from what i have read the L5P really wakes up. And i have the full banks kit on the way with the derringer, ram air and pedal monster so 1K lb torque to the wheels here i come!!
